Caryle Racing
Old 04-06-2013, 05:22 PM   #1
cam99
cam99's Avatar
Drives: 2012 ZL1
breaking up over 5500 and stabilitrack light
Took the car to the track today and it broke up bad over 5500 and ended up tripping stabilitrack light and losing all kinds of power. CEl flashed but shut off first run. Stayed on the second. Seems to run fine normal driving. It has racestar skinnies on the front (about 27 1/2" tire height) C5 vette wheels with 26" tall dr's on back. Didn't have the skinnies last year , ran stock height 20's then on the front. Stabilitrac light always tripped after about 1/2 mile of driving last year, but never affected performance. Now with the skinnies on it doesn't trip stabilitrac light driving. Also found a msd plug wire pretty scorched on the header today. Moved it to a different plug that isn't close to the header because i thought it might be arcing to the header tube. didn't change anything. Whats your thoughts ? Tire diameters making it acting stupid this year? burnt wire not holding enough spark in the high revs and tripping stabilitrac light? That's my thoughts.
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 04-07-2013, 02:31 PM   #2
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Do you have a code reader to see if you've thrown any misfire codes?
2SSCAMARO is offline   Reply With Quote
Old 04-07-2013, 04:04 PM   #3
cam99
cam99's Avatar
Drives: 2012 ZL1
No code scanner. Stopped at autozone on the way back from the track, but they can only do 2008 and older. I'm sure it's a misfire code it's breaking up hellish. I will have to get it scanned this week though
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 04-07-2013, 08:34 PM   #4
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Misfires and lean conditions (that cause misfires) will trip the stabilitrack light. See what Codes you have and if there are lean codes on one bank or both.
Rhino79 is offline   Reply With Quote
Old 04-08-2013, 10:35 AM   #5
cam99
cam99's Avatar
Drives: 2012 ZL1
Found my problem. Pulled valve covers and found a broken prc 675 valve spring. They have less than 1500 miles on them. Nice
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 04-08-2013, 03:13 PM   #6
Rhino79
Rhino79's Avatar
Thattl do it....lol. Glad you found it!
