Cold Air Inductions
Old 04-12-2013, 10:35 AM   #15
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I wish I could run the chiller, just don't want all the weight of the A/C too.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 04-12-2013, 11:12 AM   #16
old motorhead
Drives: Maggie blown LS3 vette
Didn't know you could get any Camaro without A/C....or did you just take yours off?
old motorhead is offline   Reply With Quote
Old 04-12-2013, 12:03 PM   #17
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Originally Posted by SUKXOST View Post
I'm on a 3.8 pulley and hitting 11 EASY, 12 in cold weather. I have a 1LE so it comes with the ZL1 fuel pump/tank and I have FIC850 injectors. Looks like your custom comp cam and meth are getting you that difference over my car. I'm looking into a driveability/DD cam with smooth idle and possibly meth. I was told I'd gain roughly 30WHP with a DD cam and re-tune.....guessing meth would double that at least but not sure why some are recommending no meth.
Awesome car man
Thanks bro, your's is bad ass also! I was hesitant on the Meth kit only because it was all new to me, but after a couple month of research while doing the build & speaking with Julio Don, the owner of ALKY Control, and seeing the success many of the Vette guys have running his kit, it made me a believer. It'll lower IATs, and increase HP by 25-40%, and it also acts as a safety measure as well. Not sure why shops would tell you to avoid it, talk to Cunningham Motorsports or East Coast Supercharging, they both use & love the kits.
The custom cam CMS did for me lowered my boost a little bit, I was up around 14 after adding the smaller pulley & OD Cog Drive. I could not be happier with the performance & drivability of it, plus it really gives that old muscle car rumble at idle. The Super Chiller is definitely on my to-do list.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 04-13-2013, 12:17 AM   #18
2SS45th
2SS45th's Avatar
It was taken off, doesn't do a whole lot for a car that runs primarily at the track, but maybe the IATs would be worth the weight, I dunno.
Old 04-23-2013, 04:53 AM   #19
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
I recognize the user names above, thanks for your support! It really makes a difference; I have been hammered with orders since March. Kits are going all over the world now, I’m finishing one up now for a Lumina SS (G8) going to South Africa.
ACTIVE INTERCHILLER.COM Fl INTERCHILLER
Original SUPER CHILLER Since 2009
Original XTREME CHILLER Since 2013
FACEBOOK 727 656 1422
Email Orders and Inquires
TrekGTO is offline   Reply With Quote
Old 04-23-2013, 08:02 AM   #20
rforbes
rforbes's Avatar
Drives: IOM SS/RS
It is just 7 lbs
rforbes is offline   Reply With Quote
Old 04-23-2013, 12:06 PM   #21
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Originally Posted by SmokedSS View Post
I have this same AI Chiller and it works great. My last experience @ the track and after heat soak from earlier run my IAT's were 115f when I started car to pull to stagging lanes and with chiller in comp mode within 2-3 minutes IAT's were 39f, stayed there through staging and only climbed to 89f by end of 1/4 mile run. Highway driving the other day 84f ambient temps and my water stayed low 50's f with IAT's matching, switched to comp to see difference and water dropped into low 30's F and IAT's followed.. This Chiller keeps the Maggie Cool!
Originally Posted by rforbes View Post
I agree, one of the best mods I have done. Maggie coolant temps reading 38 degrees in 100 degree temperatures.
Just out of curiosity, have either one of you made a 1/4 mile pass first without having the chiller on, then make a second pass with the chiller on, then compare time slips?
2SSCAMARO is offline   Reply With Quote
Old 04-23-2013, 12:43 PM   #22
blufin
blufin's Avatar
Drives: Fire Engine
Excellent question.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 04-23-2013, 12:44 PM   #23
SmokedSS
Guest
Drives: 2011 2SS / RS A6
Not on the same day but I have made several passes before chiller install and my IAT's start around 80f and finish around 120f and I run meth too with 12 psi boost. My tuner told me my tune was set to pull timing @ 100f IAT so I am loosing something on the top end without Dave's Chiller.. This Chiller is GREAT and Dave's support was also great..
SmokedSS is offline   Reply With Quote
Old 04-23-2013, 03:46 PM   #24
vegassam66
vegassam66's Avatar
Drives: 2012 Camaro 2SS / RS
I added the larger roto fab reservior tank and hex vents, it's been mild weather so far, i will be interested how much these help in the hot vegas summer months
vegassam66 is offline   Reply With Quote
Old 04-23-2013, 03:55 PM   #25
rforbes
rforbes's Avatar
Drives: IOM SS/RS
I know on the same setup(Before super chiller) I was running consistently 11.6-12.0 during the hotter months and got down to 11.20 running with the super chiller on a 90 Degree, 85% humidity day in Houston last summer. The car has the reaction of when you are driving on a cold day in winter during a 100 degree day. I think it certainly is better than not having one.
Old 04-23-2013, 04:48 PM   #26
2SSCAMARO
2SSCAMARO's Avatar
The only comparison that could be remotely considered a fair comparison would be back to back runs....same car, same driver, same strip, same fuel, etc. etc. Still not scientific but a good comparison.
Old 04-23-2013, 04:58 PM   #27
TrekGTO
TrekGTO's Avatar
Dyno pulls usually show Ball Park of 30HP lost with Super Chiller off in 95deg FL.
Some one posted not long ago times on vs. off but I don’t remember who it was, it may have been in one of my threads?
Old 04-23-2013, 05:32 PM   #28
2SSCAMARO
2SSCAMARO's Avatar
I'm just curious what the difference in time slip data is when comparing two back to back runs with the only difference between the first run and second run being the first run made without the chiller and the second run with the chiller on.
