Cold Air Inductions
Old 06-17-2013, 05:51 PM   #43
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I have done some back to run on and off, same car same track same day. Ran about 2-3 tenths faster with the chiller. It is ALL going to depend on when your tune pulls timing. You do not gain power with cooler water with the chiller you do however keep you IATs low enough to not pull timing, cooling hot outside air does not put more oxygen in the air but it does help from detonating and keeps IAT cooler. Here was some old data I did when I first put it on and I recheck data everytime I do a new mod and the data holds true to this day. I am now at 10.5 psi and 680hp.
Here is a copy of a post I made 2 years when I first put the chiller on and I did days of testing on the road and this is the info from that dyno testing which matched all of the road testing I did. I didn't post any graphs as I was having issues with my SCT losing connections so I never turned the logger off so it was about 30 min long.
I ok well I got the data off we needed, I tried to do a graph and all that but I am tired and not gonna do it now. So the dyno sheets I emailed to myself from the shop didn't work so I will go off of memory for the numbers there.
First off the A/C does kick off at WOT but comes back on around 4500RPM(we could see a dip in the dyno sheet. So for ALL the Chiller on tests we let it chill for 5 minutes between runs and just before we went WOT we turned off the A/C. Same 5 minutes were given for cool down for Chiller OFF.
Chiller OFF Data
101* AMBIENT
1st pull IAT start at 104*F end at 122*F car made 568
2nd pull IAT starts at 114*F end at 140*F car made 55? had a small amout of KR (.3)
3rd pull IAT starts at 125*F end at 145*F car made 54? had alittle more KR (.9)
Chiller ON
107* AMBIENT
1st pull IAT starts at 64*F ends at 113*F car made 56?
2nd Pull IAT starts at 66*F ends at 116*F car made 56?
3rd pull IAT starts at 66*F ends at 116*F car made 56?
Did a pulley change 3.6 to a 3.4 and went from 6psi to 7 psi and made 596 and the torque can't remember but it went up almost 50ftlbs. IAT were the same as the other runs with the chiller on.
I didn't tune for the chiller, we were pressed for time as they had 2 other cars that needed tuning and I was on the dyno most of the day doing 8-10 pulls. The tuner though we could get another 1-2 degrees of timing with IAT where they were with the chiller on but since we didn't have time to test I choose to stay where I was and be safer at the same power level. I think if your IATs are higher than 140*F you may get some HP out of this deal and be alot safer, but my car at 6-7PSI doesn't produce alot of heat.
I hope everyone is ok with the test as you can't please everyone but I did my best to keep a even playing field but temps came up as the day went on and engine coolant temps are what they are when we hit the go pedal. I will try to get some logs for the 1/4 mile but it isn't going to change any from what I have already done around here on the road and the dyno actually proved to heat up the car more than a 0-120mph run.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 06-17-2013, 06:08 PM   #44
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
^^^^^ thank you. It's nice to see some hard numbers. Shouldn't have to tune for this thing, it purpose is to not give back timing that is already advanced. Thanks again
Mchlgrrsn is offline   Reply With Quote
Old 06-17-2013, 06:12 PM   #45
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
^^^ Thanks Jeremy ^^^
Originally Posted by blufin View Post
I would really like for this to work at the track like I hope it would. The data looks good, the video looks good and the concept seems sound, but I have no overwhelming evidence this can create a "winter like" drag racing experience in the dead of summer. I really don't race for half the year due to the heat. If I believed wholeheartedly that this was the answer, I would RUN to get this installed. I hope something eventually changes my mind.
Where are you located in FL? We have an installation special that cant be beat. I'm excited we have our first ZL1 coming in Friday!
Just figured it out West Palm Beach DOH
ACTIVE INTERCHILLER.COM Fl INTERCHILLER
Original SUPER CHILLER Since 2009
Original XTREME CHILLER Since 2013
FACEBOOK 727 656 1422
Email Orders and Inquires
TrekGTO is offline   Reply With Quote
Old 06-17-2013, 06:37 PM   #46
Motion427
Drives: 2010 2SS/RS Red Jewel L99
This is my take on the chiller
Depends on the tune.
A stock Camaro tunes starts to pull timing at 86F.
But when the IAT are 59F and cooler,it add's timing.
So depends on how the tune is set.
I kinda like the idea of the chiller because it would make the car more consistent.Once the supercharger gets heat soak,or your stuck at the staging lane for a long period of time. If you stage at 86F on the previous run,and the next round you end up at 120F at the starting line.
Sorry!!! you just lost the race,because it will start pulling timing as soon you hit the throttle = loose power.
Once I decide which way I go with a F/I. So far leaning toward the Whipple,it will have a chiller.
Motion427 is offline   Reply With Quote
Old 06-17-2013, 06:57 PM   #47
Turbo99
Turbo99's Avatar
The only issue I have issue keeping the refrigerant level correct. Mines works great and then it works ok. I have bought some A/C gauges and see the high side go up pretty high when in comp mode. Still trying to get it dialed in correctly again. It still cools good but not as cold as I have had it before.
Old 06-17-2013, 07:47 PM   #48
GMteSSted
000107, 000574 & 699059
GMteSSted's Avatar
Drives: 3 Pre-productions - Obsession!!
This is dead on!!! I have the chiller and have run about 40 passes with it. I can't "prove" it helps my ET. What I can prove is the consistency. I won the 2012 Atlanta LSX Challenge 12 second true street in the upper 90's ambient and won the 2012 Bristol Super Chevy 12 second true street in the upper 90's ambient. Each race was a 30 mile cruise and 3 back to back hot passes. The chiller gives me great consistency. Both tracks, all 6 passes, my ET never varied more than .05 seconds. My opinion, if you want a faster car, build it. If you want consistency, and help protect your build, chill it!
GMteSSted is offline   Reply With Quote
Old 06-17-2013, 08:04 PM   #49
TrekGTO
TrekGTO's Avatar
You should bring your car in for a Free update, you were the prototype Camaro and you know the problems I had with my welder in 2011. You already had one weld fail completely and if you have to add Freon I’m sure you have a very small leak. There is no good reason for you to be adding Freon.
Jerry does all my welding now and he is 100% on the type welding needed to make all the custom fittings we use now. Also the Super Chiller is 100% O Ring connections now no pipe fittings on Freon side. You also need the updated wiring to get 100% out of Competition Mode.
Old 06-17-2013, 08:12 PM   #50
Turbo99
Turbo99's Avatar
I might have to Dave I have struggled with it the last few weeks trying to get it right. It worked great before and your right about having the first set-up. You have offered enough I think I may have to set up a time to get down there and do some updates, I have seen some pics of your new stuff and it has come a long way and looks great.
Old 06-18-2013, 11:26 PM   #51
forklord
forklord's Avatar
Drives: 2010 2SS
make an eforce kit!
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 06-19-2013, 12:09 AM   #52
Turbo99
Turbo99's Avatar
I think he has one but can't remember.
Old 06-20-2013, 07:18 PM   #53
TrekGTO
TrekGTO's Avatar
Thanks Bobby, just so everyone else understands that’s Bobby’s car in my signature!
Old 06-20-2013, 07:20 PM   #54
TrekGTO
TrekGTO's Avatar
Jeremy I will see you on the 20th for your update, I did your car 6/2011! I want to make the 30% larger core and Dual Chillers available for the Camaro; I don’t know if I will have time on the ZL1 coming in Friday but maybe something along these lines might work for you? Our Dual ZR1 works great and the 30% larger core is available as an option on all the other kits.
Originally Posted by forklord View Post
make an eforce kit!
We can do an Eforce kit but it requires the pump be relocated. Once the ZL1 kit is done we may be able to fit the Eforce without moving the pump.
Old 06-20-2013, 09:47 PM   #55
SmokedSS
Guest
Drives: 2011 2SS / RS A6
Dave, I have your setup and love it however I have just added a Night Fury cam and an OD Cog rear drive on my maggie to keep my boost around 11psi. Due to the new blower speed I am now seeing IAT's around ambient to 10 under compared to 20-30 below ambient before latest upgrade. How would the 30% larger core help and what is involved in the upgrade? thanks again for all of your support in the past..
SmokedSS is offline   Reply With Quote
Old 06-20-2013, 10:14 PM   #56
Turbo99
Turbo99's Avatar
[QUOTE=TrekGTO;6695046]Jeremy I will see you on the 20th for your update, I did your car 6/2011! I want to make the 30% larger core and Dual Chillers available for the Camaro; I don’t know if I will have time on the ZL1 coming in Friday but maybe something along these lines might work for you? Our Dual ZR1 works great and the 30% larger core is available as an option on all the other kits.[QUOTE]
I always wanted the dual, I thought it was the best back when we first did mine but at the time everything was a trial. I think either the 30% would do good or the dual. What ever you can do, my car should be in the 10's soon as I get my slicks on.
