Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#57 |
Blue Streak
Drives: 2010 SIM 2SS Join Date: Dec 2012
Time to jack up the car, remove the wheels and front bumper.
2010 CAMARO 2SS SLP TVS2300 3.4 pulley, 9PSI Custom Tune, ZL1 FP, ADM FPCM, ID 850's, tr7ix plugs, CAI intake, KOOKS 1 7/8 & HFC, Magnaflow Comp catback, Pedders Xa coilovers & sway bars & sub frame bushings Mpd1 Z hood & spoiler, Vertical doors, Hurst short shifter, R1 dimpled/slotted rotors, SS brake lines, Hawk HPS Pads, Niche Apex & Nitto Invo front:20X10-275, rear:20X10.5-315, GM GFX & Satin gas cap, RS projectors, T3 bumper ports, T4 splitter, Alpine INE-W927HD, Metro dash kit
#58 |
Blue Streak
Pic of the SLP air exchanger.
#59 |
Blue Streak
Side skirts removed.
#60 |
Blue Streak
Rear bumper removed.
#61 |
Blue Streak
Front bumper with Heritage grill. Before pic.its on cardboard cause ill be adding the T4 splitter so I don't care if it scratches on the bottom.
#62 |
Blue Streak
Heritage grill installed. Easy peasy. So much nicer/cleaner IMO.
#63 |
Blue Streak
The GM instructions with the GFX kit are awesome for removal. And I made sure I kept them for installing so I don't have any extra bots/screws left over. I install the RS headlights (with Olfer's harness). Took me 15 min to do this. Works perfect. Sorry, no pics on this as was too fast to do. I'm done for what I can do without tools need tomorrow. So I crack another cold one and go home.
#64 |
Blue Streak
Saturday morning. Plan of attack. Front bumper 1st. ACS T4 splitter install and T3 bumper ports. T4 was peanuts to install. Fit was awesome. Bumper ports are some work. Marked out the cutout and got the Dremel out. It took a bit to find the "sweet spot" of the Dremel. One we got it, cutting like butta.
#65 |
Blue Streak
Did the same on the other side, glued the backing part and let it cure over night. While my uncle was doing that, I installed the GFX side skirts.
#66 |
Blue Streak
And then the ZL1 rear spoiler. This was a bit to do. You need to drill a hole for the 3rd brake light wire to go through the trunk lid. Also, you need to remove the rear cover (where the speakers are) to get access to that 3rd brake light to install Offer's harness to make the ZL1 light functional. You also either need to make 2 more holes as thenZL1 has 2 more fastening threads or cut those off. I cut them as the spoiler is still held by 4 screws and 3M neoprene tape gasket After you install the spoiler, you are left with 3 holes from the stock spoiler. I will plug them up for now and will get it to get filled at a later date.
Spoiler installed.
#67 |
Blue Streak
It looks so good.
#68 |
Blue Streak
It's hard to see in this pic, but look hard. 3 holes that need to be filled. I found out that GM has a paint issue on the 2010's. so when I took my stock spoiler off, my paint chipped from the spoiler location. I'll bring it in to see if they will cover it. I'll pay to fill the holes.
#69 |
Blue Streak
Uncle finishes bumper ports and helps me out. Next rear bumper. Not too hard. It's a 2 person job as the GFX is too flimsy for one person to handle. I'm sure you can, just much easier with 2. Same with installing the bumper back on to car.
#70 | |
Est.1775
Drives: '15 Challenger Hellcat (sold) Join Date: Sep 2009
Thread Tools | |
