Emblempros
Old 04-07-2013, 08:06 PM   #1
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
1LE Factory Tire Pressure
I was wondering if any of the 1LE owners would be able to look on the info tag inside their drivers door to see what the factory tire pressure recommendations are for the front and rear.
Thanks in advance!
Nick S is offline   Reply With Quote
Old 04-07-2013, 08:10 PM   #2
tbirdsleeve
CMSgt, USAF
Drives: 2013 1LE Camaro
32 PSI
tbirdsleeve is offline   Reply With Quote
Old 04-07-2013, 08:21 PM   #3
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
confirmed!
cornerspeed92 is offline   Reply With Quote
Old 04-07-2013, 08:26 PM   #4
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
so the 23lbs I dropped them to @ the drag strip that tripped the warning to add air wasnt right?
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 04-07-2013, 08:31 PM   #5
Cooley
Cooley's Avatar
Drives: 2013 2SS 1LE
Cooley is offline   Reply With Quote
Old 04-07-2013, 08:33 PM   #6
cornerspeed92
then that means the 29 i ran at Laguna wasn't right too
Old 04-07-2013, 08:38 PM   #7
SUKXOST
SUKXOST's Avatar
Course vs strip but....
If I remember right:
I took a pass @ 29 lbs and went 12.4 (2.1 60' @ 125)
Dropped to 24lbs and went 11.71 (1.87 60' @ 123)
Dropped to 23lbs and went 11.67 (1.83 60' @ 123)
Old 04-07-2013, 08:42 PM   #8
Nick S
Nick S's Avatar
Thanks for the replies everyone!
Old 04-07-2013, 09:22 PM   #9
cornerspeed92
Thats amazing that such little gains/losses in pressure make such a difference,nice pass
Old 04-08-2013, 04:19 AM   #10
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '17 HBM M6 ZL-1!
OMG, my 1LE was delivered to me with 44 psi in each corner. It felt like I was driving on bowling balls until I lowered them. I'm not sure if the factory or the dealer did it. Did everyone else's come with "Nitrofilled" from the factory or was this a dealer addon for my car? It came with the white-logo-ed valve caps that look horrid on the black wheels.
Tara
Okay, ok; I know where my Camaro is now! In my driveway!
Tara Martin is offline   Reply With Quote
Old 04-08-2013, 11:49 AM   #11
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
That could be driver improvement as he got use to the track condition, he varied the launch RPMs or the track was improving. Typically a 35 series DOT track (road race) tire is not effective at a drag strip because the sidewall is so stiff it doesn't allow for weight transfer. I am actually suprised that the 60fts are that good on the stock tire! Nice driving!
-Matt
Old 04-08-2013, 11:59 AM   #12
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
-Matt
I agree. With wrinkle wall slicks, pressure is a huge deal, but these new tires I would not have thought were as responsive to pressure changes. It would be interesting to note any other changes like launch RPM and / or weather conditions.
gajagfan is offline   Reply With Quote
Old 04-08-2013, 09:49 PM   #13
Nick S
Nick S's Avatar
With lower tire pressure though on the good years you may not get sidewall wrinkle but you will effectively increase your contact patch area which will give you more traction. With less pressure the flat spot on the bottom will become bigger thus give you more grip.
Obviously the tire is not really intended for drag racing with the low sidewall but lowering the pressure can still help a bit.
I'm sure with SUKXOST though he did improve his driving as he warmed up to the track.
Old 04-08-2013, 09:54 PM   #14
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Tara
Mine came in at 38 psi and I dropped it down to 32 psi I'm thinking of going with 30 psi. No Nitrofill either.
Firefighter is offline   Reply With Quote
