HURST
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 04-08-2013, 11:04 AM   #1
biglou87z28
Drives: 1987 IROC-Z , 383 Stroker
Tire / wheels Adice PLease!!
Hello All,
I have an 87' Iroc-Z, final product is a 383 stroker, approx 480 HP, approx 510lbs torque, Moser 3.89 9" Rear, Tremec TKO-600 5 speed, totally overhauled UMI Suspension, RAM dual disc hydraulic clutch... We are keeping the stock Iroc wheels, as many of you know the stock tire is a 245/50/16..
The car will be used as a weekend toy, dry weather conditions
Need some direction:
1- Do I go with Drag Radials? If so, all around, or just the rear?
2- What size should I run? 255's I hear fit no problem.. How about 265's?
3- Do I go with the same size all around?
Any guidance you guys can give is much appreciated!!
I am open to any suggestions..
Thanks for your feedback!
Lou
biglou87z28 is offline   Reply With Quote
Old 08-01-2013, 10:48 PM   #2
Obsessive Camaro Disorder
Obsessive Camaro Disorder's Avatar
Drives: 69 Camaro and 92 RS
hey, you probably already have tires but i would highly recommend the BF Goodrich. 245/50r16 gforce sport 2's i think and the BFG drag radials 255/50r16. I had this set up on my 92 and i really liked it. i still have the same size tires on their now just not the drag radials. they were too expensive to replace considering how little use they get.
Obsessive Camaro Disorder is offline   Reply With Quote
Old 08-02-2013, 09:08 AM   #3
demonspeed
demonspeed's Avatar
Drives: Ordering 2017 SS
I'd certainly run drag radials in the rear. Stick with your stock size in the front if you're going to run the factory 16"s. You could go a little wider on the rear so as not to throw off the aspect ratio; however, you might want to consider sending them out to get widened.
demonspeed is offline   Reply With Quote
Old 08-02-2013, 09:17 AM   #4
DwRed1LTV6
Drives: '11 VR 2LT HHr
Nice sounding Iroc-Z
how bout some pics... !
2011 Hhr
