BeckyD @ James Martin Chevy
Old 04-08-2013, 11:59 AM   #1
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
How to tell the difference between ZL1 Fuel pump and SS?
Anyway to tell the pumps apart? Wondering if I didn't get SS pump instead of the ZL1 pump. Only sticker on the pump is the tracking sticker. not sure it would tell anything.
Nitroman28 is offline   Reply With Quote
Old 04-08-2013, 04:39 PM   #2
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
I looked at my stock SS pump and the numbers on the sticker are different then yours.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 04-08-2013, 06:18 PM   #3
Nitroman28
Nitroman28's Avatar
Did you get any installation directions with your ZL1 pump? if so what was the part number on them?
Old 04-09-2013, 09:04 AM   #4
MANNYS2SS/RS
Hope this helps you.
Old 04-09-2013, 10:45 AM   #5
Nitroman28
Nitroman28's Avatar
Yea, That's the same instructions I got, The part number on that box is for 3:91's.
I give up, No idea why the FPCM and pump is not working for me. Guess it's time to order a dual pump and be done with it.. Thanks for taking time to help me with this.
Old 04-09-2013, 11:09 AM   #6
Chevrolade
Drives: 2010 2SS/RS
Is it a direct swap?
Chevrolade is offline   Reply With Quote
Old 04-09-2013, 11:19 AM   #7
Nitroman28
Nitroman28's Avatar
If you're talking about the Dual pump, Livernois has one that's direct swap. The Lingenfelter pump you have to change the FPCM and some wiring..
http://www.livernoismotorsports.com/...-Assembly.html
Old 04-09-2013, 12:15 PM   #8
POS Dakota
POS Dakota's Avatar
Drives: GMs and Chryslers
This is what you need.
http://www.livernoismotorsports.com/...-PUMP-KIT.html
I have a complete aeromotive stealth fuel system on my truck and it's been solid.
It will also supply any future upgrades I can conjure up within reason.
POS Dakota is offline   Reply With Quote
Old 04-09-2013, 12:34 PM   #9
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
So the ZL1 pump and ADM FPCM isn't working for you? What RWHP are you at? M6 or A6? What type of power adder do you have?
Old 04-09-2013, 01:27 PM   #10
Nitroman28
Nitroman28's Avatar
On the dyno Sat I was putting down 570, 10psi. I have an A6 with a TVS2300. On the dyno the FP is fine, But at the track it drops into the 40's. I added meth with a small nozzle, It helped the AFR but didn't do anything with FP. Wondering if Pace didn't send me another SS pump instead of a ZL1 pump. Doesn't seem there is anyway to tell the 2 apart.
Fuel (psi) is at the rail
FP (ecm) Is from the ECM
Dyno
Track
Old 04-09-2013, 03:41 PM   #11
VADER SS L99
Call and talk to Andy and see what he says. I would think you would be good to at least 600rwhp.
