Solo Performance
Old 04-08-2013, 05:02 PM   #1
orthojoe
Drives: Subaru BRZ, Porsche Boxster Spyder
Carbon Ceramic rotor on Z/28 : concern
The new Z/28 really has my attention. GM really has impressed me with making a car strictly for a small set of enthusiasts who enjoy tracking their cars on a regular basis. I am glad to see that GM thinks this is an important market segment because the sport has been growing in popularity over the past few years. They have the insight to know that there is something to making a car for this growing sport.
The only concern I have about the car currently is how heavy it is. 3800 pounds is lighter than a ZL1, but still considered VERY heavy for a track car. Traditionally, heavy cars are not as nimble, overheat, and are costly in terms of consumables. I can see how the car can still be engineered to be nimble, and how coolers and the right components can make it reliable in terms of heat management. However, I do want to bring up my concern on consumable cost with the carbon ceramic brakes:
Carbon ceramic brakes (CCB) are expensive. Why would they put these types of brakes on the Z/28? My guess is that CCB brakes are necessary for a car this heavy and this powerful to prevent brake fade. I doubt that standard steel brakes would be able to hold up lap after lap in a 3800+ pound car that makes 500HP. While CCB last longer than steel rotors, they still wear out. I have experience with CCB on a Porsche, and must say that they serve no purpose for track use. They only last a few days more than regular rotors during track use, you can't use aggressive track compound pads or else they will wear much sooner, and the cost to replace ($4k per rotor) is prohibitive to use in a track environment. Most Porsche guy that track their cars ditch the CCB rotors and put steels on. They can get away with this because those cars are lightweight cars (~3000 lb), and fade is not an issue. In a Z/28, this might not be an option if the car is too powerful/heavy for regular steel rotors. So the question now is: How much will it cost to replace these Z/28 CCB rotors, and how often will they need to be replaced? I wonder if this could be a potential achilles heel for the car.... Thoughts?
orthojoe is offline   Reply With Quote
Old 04-08-2013, 05:08 PM   #2
Bomino
Bomino's Avatar
Drives: 2011 2ss/rs
I read somewhere GM stating that the CCB's will likely last the lifetime of the car.
also, Wilwood has CC rotors for the mustang (and i was told they are bringing them out for the camaro) and they are 1K each, not 4K. i doubt the brembos will be 4 times the cost of the wilwoods.
Bomino is offline   Reply With Quote
Old 04-08-2013, 05:43 PM   #3
orthojoe
They'll last the lifetime of the car if you don't track it regularly. They'll wear out if they're tracked. Unfortunately I have personal experience with CCB at the track. 1k per rotor is certainly easier to swallow thank 4k. Good to know. Thanks!
Old 04-08-2013, 06:32 PM   #4
Synner
Drives: not stock
The rotors should easily last over 80k miles or 15-20k if you track it a lot. You can find the corvettes for 900-1200 each depending on where you look. I don't know where people are getting the crazy prices from.
Old 04-08-2013, 07:50 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Just an FYI - rotors are iron, not steel.
CCB rotors run about a grand each.
Click to view my build thread
Old 04-08-2013, 08:05 PM   #6
orthojoe
~$1k per rotor is more palatable, particularly if they can last 15-20k with a lot of tracking. Good to know. Thanks!
Thanks!
Old 04-08-2013, 08:23 PM   #7
OldScoolCamaro
...it's a very durable material..only detraction is they are very brittle, and will crack it banged upon.
Old 07-07-2013, 02:04 PM   #8
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
The ZL1 metal rotors seem to wear fairly quick and are about $500 each. So I wonder if the carbon rotors is a good replacement option on the ZL1?
2017 C7 GS - WGG, A8. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 07-07-2013, 03:32 PM   #9
1leNPP
Drives: 1LE , 1SS , NPP
I think the best place to ask on how well the CCB hold up on a track would be the C6 Z06 forums http://forums.corvetteforum.com/c6-z06-discussion-100/ and this part of the forum for steel brakes hope this help in your search http://www.camaro5.com/forums/showthread.php?t=71401
1leNPP is offline   Reply With Quote
Old 07-07-2013, 04:57 PM   #10
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
good thread!...I have the same concern. I believe the ccb dissipates heat better and will not fade under the most rigorous applications...ie endurance racing. The typical track day session for me is 20-30 minutes. I would switch to steel, run super600, aggressive pads and see where that takes me for the @6hr track weekends. I really can't afford buying new ccbs often.
backtotintops is offline   Reply With Quote
Old 07-07-2013, 09:10 PM   #11
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
The brakes save a lot of weight, unsprung too. Camaro brakes are already huge and if u ever picked a rotor up you realize how heavy they are. Now imagine trying to go larger for more output? CCM gives u a lighter, larger rotor and yes, they can handle the heat better.
Honestly, if u are willing to drop z/28 money, 1-2k per rotor is not bad considering ZL1 rotors are $500 and the CCMs might now last longer then equal iron rotors but u will eat ZL1 rotors with thise trofeo tires, plus you will most likely fade.
http://www.sglgroup.com/cms/internat...ml?__locale=en
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 07-15-2013, 07:27 PM   #12
Hyena
Drives: 2013 1LT RS CRT
for GM factory ZR1 rotors they are $2408.72 each....times 4 = $9634.88 total.pads are $906.00 for the front and $672.00 for the rear.
I would highly doubt that the Z/28 rotors and pads are going to be much cheaper.
as for a carbon ceramic matrix rotors and pads serve no purpose on the track,that is completely wrong.this setup works by heat.the more,usually,the better.if you can't get them to work on the track,then you aren't driving hard enough.another way of looking at it is,every team in formula 1 uses cabon/carbon setups for a reason....they flat out work( in the dry) the best for what the rules state.
MotoGP uses them as well,but will switch them out in bad weather,because you can't keep heat in them in the rain.thier use in other series would be more wide spread if the cost came down.
Hyena is offline   Reply With Quote
Old 07-17-2013, 01:42 PM   #13
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
Are your prices from a local dealer? Online parts sites charge much, MUCH less than dealer.
zr1 front rotor PN 25843121
zr1 rear rotor PN 25843128
'GM parts direct' price $1222.34 ea
And I wouldn't doubt that you could find them for even cheaper than that.
Moreno Motorsports is offline   Reply With Quote
Old 07-26-2013, 04:45 PM   #14
Dega Man
Drives: ZL1
The Z28 rotors will not be a direct fit on the Zl1 due to size difference. The Z28 rotors are 15.5 in dia front and 15.3 in dia rear. The Zl1 rotors are 14.6 in dia front and 14.4 in dia rear.
Dega Man is offline   Reply With Quote
