Old 04-09-2013, 08:42 AM   #1
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Questions about Torque Management-LS3 Manual
Can anyone tell me definitively whether TM is in play during the initial start-up Open Loop operation of the vehicle.
No guessing allowed
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
f5journal is offline   Reply With Quote
Old 04-09-2013, 09:35 AM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
There are no TM vs ERT (engine run time) tables (so I won't guess) but why wouldn't they be in play all the time?
Until it's warmed up in CL I wouldn't want to whup on it anyway. I try to wait until the oil is over 200*f.
When you go WOT it's open loop anyway.
There are closed loop vs ERT tables & factors upon startup.
Iam Broke is online now   Reply With Quote
Old 04-09-2013, 09:45 AM   #3
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
I know after they were removed via tune the car is a whole different animal for sure.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 04-09-2013, 11:29 AM   #4
f5journal
f5journal's Avatar
OK, the point of my question has to do with the way my car runs in open loop vrs closed. It has incredibly more throttle response and spins the tires easily until it goes into closed loop.
So, although I have a JRE tune in which I am pretty sure TM is dialed down some, I am wondering if the open loop difference in performance might be that there is no TM during that period.
Iambroke, I asked a leading question on another thread where you had posted HP screen shot of TM table..I'm looking to be able to tweek a few things myself.
Old 04-09-2013, 11:37 AM   #5
aj2ssrs
Drives: IOM 2SS/RS
GM limits torque to 280 ft lbs at 3,000 rpm and lower in all gears. I know Ted disabled this when he tuned mine.
ADM race intake, Dynatech lt headers w/hi-flo cats, Jannetty Racing dyno tune, VMax CNC ported TB, MGW short throw shifter, Elite Engineering catch can
aj2ssrs is offline   Reply With Quote
Old 04-09-2013, 11:50 AM   #6
Iam Broke
PHAT B33
Iam Broke's Avatar
How fast does it go into closed loop? Mine only takes a minute. There's a table for that.
It may be tuned richer in OL. Closed loop it controls at stoich.
Old 04-09-2013, 11:56 AM   #7
f5journal
f5journal's Avatar
I cannot say for sure, but it seems like about 4-5 minutes. I can get out of the neighborhood, and nail it on the main 2-lane road. By the time I make the next turn about a mile or so up the road it is a different car.
I kept thinking it was all cold tires, but that is bull. There is something happening in the open loop that needs to be changed in my tune (I think)
And TM/throttle delay, something similar appears to be it to me.
Old 04-09-2013, 06:15 PM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
I guess you better ask Ted about it then.
Old 04-10-2013, 08:48 AM   #9
f5journal
f5journal's Avatar
will do ..thanks all
Old 04-10-2013, 09:18 PM   #10
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
Apoloigies for not understanding, but what is the loop that you are talkng about?
Surely my car feels like it has a tremoundous amount of power at times and at other times much less...
Have been wondering about it when i came across your thread.
Bucci
Bucci is offline   Reply With Quote
Old 04-10-2013, 10:23 PM   #11
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
The car runs in what is referred to as Open Loop until it reaches certain parameters including engine temp. The O2 sensors feedback is not controlling the mixture via the ECM. The car runs on a preset table for fuel and spark that was programmed into tue ECM.
When all of the criteria are met the O2 sensors provide feedback and this allows the ECM to adjust fuel and other things live, based upon the feedback. This is called Closed Loop, as the engine is being adjusted real time based on measurements relative to its performance.
chef-beavis is offline   Reply With Quote
Old 04-11-2013, 11:24 AM   #12
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
Many thanks for the explanation! I had no idea... will do some research and get up to speed...
Thanks Again!
Bucci
Old 04-11-2013, 10:58 PM   #13
grocerygetter
instigator
grocerygetter's Avatar
becareful beating on a cold engine. I try to limit rpms and throttle input until you are up to running temps. many things such as valve springs etc will thank you.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 04-12-2013, 05:10 AM   #14
MA2010SS
Drives: 2010 Camaro SS
Agree you shouldn't be running a car hard when the car is cold
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
