Old 04-09-2013, 08:42 PM   #1
mc_acoustic
Drives: 2010 1LT Limited Edition Camaro A6
Easiest kit to install.
Which nitrous kit is the easiest one to install for the 2010 v6?
mc_acoustic is offline   Reply With Quote
Old 04-09-2013, 08:56 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Either the ny trex or nitrous outlet.
Old 04-09-2013, 09:03 PM   #3
mc_acoustic
Is there anyway a newbie can install nytrex?
Reason why i ask is because in my small city... the cheapest install of nitrous is like 800 dollars... Which is more then the kit itself to begin with new...
Old 04-09-2013, 09:14 PM   #4
lscamaro
lscamaro's Avatar
Yes, I'm sure you could install it. I believe the nytrex even comes with a harness to help you with wiring (I believe it does, don't quote me on that). If you have questions, I would highly suggest contacting member etmx183. He's already installed a few of the nytrex kits and is a mechanic as well so he could offer you some tips. The hardest part will be running the wires to wherever they need to go. I would be a little weary of installing it though if you have no idea what you're doing. I was going to get mine installed by a professional when I was going with nitrous.
Old 04-09-2013, 09:16 PM   #5
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
I'd leave nitrous install up to professionals
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 04-12-2013, 05:34 AM   #6
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
The basic nytrex kit is pretty simple, it should take a shop about 2-3 hrs to install, $800 is too much to pay. It gets complicated when installing their progressive controller. I payed $600 for a shop to install my setup which includes a controller, opener,heater and a fancy switchplate in the cupholder.
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 04-12-2013, 05:56 AM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
N2O isn't that hard to install... key is to make sure you have all the safety pieces like a window switch and I also recommend you put the car on the dyno with a wideband to verify your AFR before you run it at the track...
scrming is offline   Reply With Quote
