JUICEDMOTORSPORTS
Old 06-22-2009, 07:52 PM   #1
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
K&N Replacement Air Filter
K&N’s replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
33-2434 Product Specifications
Product Style: Panel Air Filter
Height: 1.625 in (41 mm)
Outside Length: 11.625 in (295 mm)
Outside Width: 9.125 in (232 mm)
CFM: 588.3
Filter Re-Oiling Amount: 1.87 oz (55 ml)
Weight: 1.7 lb (0.8 kg)
Product Box Length: 12.31 in (313 mm)
Product Box Width: 1.19 in (30 mm)
Product Box Height: 14.06 in (357 mm)
Kahdir is offline   Reply With Quote
Old 07-12-2009, 08:32 AM   #2
santi1987
santi1987's Avatar
Drives: 2010 Camaro LS
Send a message via AIM to santi1987
who order and what result they got?
santi1987 is offline   Reply With Quote
Old 07-12-2009, 08:55 AM   #3
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
I've had them on several of my vehicles. They work. Nice sound too. The FIPK I put on my Silverado gave me a nice little performance boost.
patriotpa is offline   Reply With Quote
Old 07-12-2009, 10:53 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Installed mine yesterday. Going to run a tank or two of gas and see if milage picks up. Engine sounds meaner.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-12-2009, 01:38 PM   #5
buddylok
buddylok's Avatar
Drives: Chevy
I installed mine few days ago, didn't notice any milage increase. but engine do run smoother.
go for it !
buddylok is offline   Reply With Quote
Old 07-12-2009, 01:38 PM   #6
acehole
Drives: mits lancer oz
Ok so what is the difference between the K&N filter and cold airintake ? K&N filter $57.00 cold air intake $400.00 plus...is there that much difference in HP and gas milage ?
acehole is offline   Reply With Quote
Old 07-12-2009, 06:36 PM   #7
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Lots of difference between the cold air intake and just replacing the stock filter with a K & N.
K & N filters have better airflow and better filtering properties, so your fuel to air mixture will not see delays in air intake, making your fuel mixture overly rich (more gas than air initially for engine demands). This creates a rich fuel / air mixture. A lean fuel / air mixture is too much air to fuel. Your engine has been set up for a specific fuel / air mixture to get peak performance and stock air filters can slightly restrict the needed air at times and they tend to clog with contaminants much sooner than a K&N.
An excessively lean mixture will cause an engine to run hot and usually sputter. An excessively rich mixture will create carbon deposits on your spark plugs and in the engine cylinders, valves, etc. This will lead to poor mpg and lack of power.
A K&N allows good airflow under all conditions, so when you accelerate, there is not as much lag of air for the mixture as there would be with a standard filter. This is why it is claimed a K&N increases mpg. It is also why it is claimed to increase power - a constant good fuel/air mixture creates a good constant burn in the cylinders and lets your engine run at peak performance.
This is all talking about simply removing and replacing your stock filter with a K & N - good idea.
A cold air intake removes the air filter box that holds your stock filter and installs just the open air filter, so any restrictions in the stock system are removed and the filter is simply wide open under the hood, taking all the air it needs, whenever needed with absolutely no restrictions. The price pays for a replacement tube from the engine inlet to the open air filter and any mounting needed to secure the tube and filter under the hood. You will be completely removing the stock air filter assembly - but it is NOT a difficult task and will not have any adverse affects on your engine - only increased power and mpg. Warranty is not affected. Cold air intake great idea.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 07-12-2009, 07:03 PM   #8
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
So if I go with the Cold Air Intake, I should not get the K&N filter?
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 07-12-2009, 07:35 PM   #9
RS_Man
RS_Man's Avatar
Drives: '13 Sonic RS 1.4T M6
K & N is a JOKE. Their filter is overpriced and does not increase HP much more than a stock filter. I've had better luck with cheaper high performance filters you can buy from Autozone. I have run a couple vehicles on a dyno with a K&N vs cheap, and saw that the cheaper filters gave more gain. Basically you're paying for a name. I put together a short ram intake, virtually identical to a K&N setup for my truck, paid maybe $50 instead of $400 and got better results.
RS_Man is offline   Reply With Quote
Old 07-12-2009, 07:59 PM   #10
derin11
Drives: 2010 Camaro 1LT
I want to make my old cold air intake, how do i do it haha?
derin11 is offline   Reply With Quote
Old 07-12-2009, 08:25 PM   #11
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
As far as CAI... used to be a cold air intake meant you were sucking air outside the engine bay... usually through the fender wall... Now it more of a box with a open filter... and your hoping the box holds the engine bay heat away from the filter....
I went to the track today... i did some data logging and was surprised how much the intake temps dropped once the car got moving! So it appears to me the stock air box is doing a pretty good job of grabbing fresh air from the front! I haven't really checked out it out... the stock box is sucking air from right behind the grill area.. just not sure what's all up there blocking things...
Here's the log... click to see full size.. then check the intake temp (light blue)... actually starts to drop once i hit about 20MPH...
scrming is offline   Reply With Quote
Old 07-12-2009, 08:29 PM   #12
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I bought on a couple weeks ago, but I don't have a car yet. This was I needed on my 4th gen, and a new lid and wolaah. Only difference here, the new SS is missing the ram air.
tjbusa is offline   Reply With Quote
Old 07-12-2009, 08:32 PM   #13
scrming
scrming's Avatar
i tried to buy one... figured while I had the car on the dyno what the heck.... called the local parts store.. guy tells me they don't have the 2010 Camaro in the system yet... then says, "Well, wouldn't it be the same as the 2009?"
Old 07-12-2009, 09:02 PM   #14
Fire
Drives: 1999 Firebird Formula
Conical K&N and some Home Depot pvc piping. Saved $350. Booyah.
Fire is offline   Reply With Quote
Missing air filter on a 01 Cavalier jstein General Automotive + Other Cars Discussion 4 06-06-2009 09:33 AM
Intake/ Air Cleaner observations and thoughts... (?V6/V8?) radz28 5th Gen Camaro SS LS LT General Discussions 27 01-23-2009 08:14 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 11:00 AM
What do you think a K&N Air Filter would do for L99? Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 11-02-2008 11:22 PM
question about K&N air filters Dave McFly General Automotive + Other Cars Discussion 6 07-16-2008 09:38 AM
