JUICEDMOTORSPORTS
Old 04-10-2013, 11:25 AM   #1
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2013 Camaro TT LS3
ZL1 pump install question
Can a ZL1 pump be installed to replace the stock SS fuel pump WITHOUT any programming - just a plug-and-play type of install? Or will it need a tune? Will have the rear cradle out and thought it might be a good time to preempt future mods to install the ZL1 pump. Just want to replace pump for now - injectors at a later time when needed Thanks!
945WHP / 951WTQ at 13.7psi on E85 (1.286 dyno correction factor) 10.8sec@129mph DA 7,724ft at 14psi boost on SBE
AGP 56/61 TT | BTR Turbo Stage III cam | AEM TruBoost | n2mb WOT | ID-1000s | NGK BR7EF | DSX Flex Fuel Sensor | LPE
Twin Fuel | KB BAP | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 04-10-2013, 12:48 PM   #2
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Yes, plug and play. No tune adjustment necessary. To take advantage of the increased pump capacity, you will need an ADM FPCM.
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 04-10-2013, 01:59 PM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
...and a tune later to raise the fuel pressure setpoints if SC'd.
Iam Broke is offline   Reply With Quote
Old 04-10-2013, 02:06 PM   #4
dreksnot
dreksnot's Avatar
Exactly the answers I was looking for -
Old 04-11-2013, 02:36 AM   #5
injector
injector's Avatar
Drives: LS3
If i were you i would go LPE or Squash Return style fuel setup. A lot of guys will start with Headers and Filters and end up with S/C and a stroked engine.
Why paying twice to change later..
Texas Speed & Performance Custom Built Forged 408 CID, PRC LS3 260CC,Fast Intake & NW 102 TB, Alky Methanol kit, ID850, LPE Dual pumps,,Melling HV oil Pump. D1SC 10PSI, Stage 2 Air Intake,Magnaflow Axle back, Mcleod clutch, Pedders XA coilovers and sway bars, HD bushings, Hurst shifter, ACS bumper and hood ports, DSS aluminum drive shaft, CSF radiator .
injector is offline   Reply With Quote
Old 04-11-2013, 07:56 PM   #6
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Or
Adm Performance twin pump system
ADM PERFORMANCE is offline   Reply With Quote
