Old 04-11-2013, 12:34 AM   #1
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
Tap shift after tuning
Guys -
Is it possible to keep the S mode tap shift after tuning? What I mean by this is that in D, when you use tap shift, I think depending on RPM and also when you come to a stop, it reverts from M back to D automatically. Before the tune, I could go to S and use tap shift and regardless it would stay on M. Because of the tune, S for me runs like crap since the tune is on D is what I understood.
Hope that makes some since.
Thanks
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
Old 04-11-2013, 06:51 AM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
There will be no engine performance difference between s and d. Your tuner should have tuned both the sport and drive mode, and yes tap shift in drive will default back to drive after a short time of no tap activity. In sport it will stay in manual tap mode.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 04-11-2013, 07:15 AM   #3
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Your car does not revert back to D after stops. If your shifter is in S and you're using paddles and come to a stop you will still have to shift using paddles however it will autmatically downshift and take off in 2nd for you but you will be on paddles. Tune makes no difference what mode you're in.
Old 04-11-2013, 10:27 AM   #4
Camero5
Camero5's Avatar
If your in D mode, and use tap shift, when you slow down is will auto downshift with RPM and when you come to a stop revert back to D. That's a normal function in the camaro when in D. Only in S will it stay in M when your using it.
Unfortunately, Rhino is right, the tuner didn't replicate the tune to S. If I switch to S it doesn't drive like it should.
