Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 11-30-2013, 06:17 PM   #43
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
Pm price to 78572 please
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 12-10-2013, 05:23 PM   #44
RigidFrame
RigidFrame
RigidFrame's Avatar
Drives: 2010 2SS/RS IOM
PM price shipped to 70605 please.
RigidFrame is offline   Reply With Quote
Old 12-11-2013, 06:02 PM   #45
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
BC Racing/MEGAN Coilovers for Sale FREE S/H
Nobody will beat our prices!
Save on
BC Racing BR Coilovers
Megan Street Series
Megan Spec-RS
OHIO SPEED is offline   Reply With Quote
Old 12-20-2013, 09:05 PM   #46
WONSS
WONSS's Avatar
Drives: 2012 1SS/RS M6 SUMMITT WHITE
plz pm price on bc's...12 ss camaro
WONSS is offline   Reply With Quote
Old 12-21-2013, 03:26 PM   #47
OHIO SPEED
OHIO SPEED's Avatar
Ohio Speed now offers BC RACING and MEGAN Coilovers.
BC Racing BR Series Coilovers:
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
BC Racing ER Series Coilovers:
BC Racing's newest and most advanced model yet is the ER series coilover for the 2010+ Camaro. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30-way, rebound and compression tuning dials.
52mm Mono-Tube Shocks
External Reservoir Mono-tube shock design
30 levels of damping force adjustment, adjusts both compression and rebound separately
Twin piston design
Separate full length height adjustable
One year warranty
Rebuildable
Technical
The enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating.
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
Iron lower brackets on MacPherson struts to ensure rigidity.
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion.
Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Separate full length height adjustable
- One year warranty
- Rebuildable
MEGAN Street Series Coilovers:
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 8 kg Front and 10 kg Rear
- 32 Levels of Adjustable Damper Strength
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil over damper kits come with 1 year manufacture-defect warranty.
- Must reuse the factory top hats.
MEGAN SPEC-RS Series
Megan Racing introduces the new SPEC-RS Coil Over system features 32 levels of damper force adjustment, where compression and rebound adjustments are separate for increased tuning capability. The coil-over body also features separate spring perch adjustment and full shock height adjustment independent of spring pre-load to retain full suspension stroke while allowing the vehicle to be corner-balanced, which is often an integral part of suspension tuning as an aggressive alignment. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for to reduce suspension deflection and camber plates are utilized for strut-type suspension applications.
Compression and rebound settings are easily adjusted through a individual adjustment knobs located at the top of the damper for compression adjustment and on the external reservoir for rebound adjustments. With a twist of the knob, adjusting compression and rebound settings are simple to tune according to your driving style and suspension setup whether you are a professional certified mechanic or an automotive enthusiast with amateur mechanical skills. All of our dampers are capable of handling a +2kg/mm or -2kg/mm change in spring rates to further tune your suspension to your desired handling characteristics.
Height adjustments are made with separate CNC-Machined locking spring perches for accuracy and smooth adjustment with separate damper shock length adjustment to retain full-stroke and allows for precision suspension tuning. The range of allowable ride-height adjustment allows you to retain the factory ride-height for OEM appearance with performance handling, or fine tune your suspension for the race-track to lowering your center of gravity to gain full potential of your vehicle's handling capabilities.
On applications utilizing strut-type suspension designs, the Megan Racing SPEC-RS Coil-over Damper Kits come with fully adjustable Pillow-Ball upper mount camber plates to easily tune and adjust your camber, giving you a competitive edge over other suspension setups. This allows you to tune your car for ride height and still adjust camber to improve handling, vehicle predictability and tire wear, which is a great benefit both on the race-track and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which is then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
SPRING RATES:
F: 62mm ID; 180mm length; 8kg/mm
R: 62mm ID; 170mm length; 12kg/mm
DAMPER SPECS:
F: 120mm stroke; 260mm length
R: 100mm stroke; 200mm length
- External Reservoir for additional oil capacity and separate compression adjustment (New feature)
- Rubber Dust Boots
- Dual-Cylinder Design
- Steel front brackets/ Aluminum rear aluminum Brackets
- 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
- All Hardware is Included
*Height adjustment on Spec RS coilovers requires loosening remote reservoir bracket bolts
PM FOR OUR LOW PRICES WITH FREE S/H
Old 12-29-2013, 11:09 PM   #48
Roger Stattel
Drives: 2012 Camaro 1ss
Pa a price to 92026
Roger Stattel is offline   Reply With Quote
Old 01-03-2014, 09:10 AM   #49
Colbyss
2SS/RS
Colbyss's Avatar
Drives: Rally Yellow 2SS/RS
Shoutout to Ohio Speed! Very pleased with my BC Coils!
Sent from my Motorola T900 Talkabout
2SS/RS w/ Vararam, Kooks LT Headers, Borla Atak cat-back
Colbyss is offline   Reply With Quote
Old 01-03-2014, 05:01 PM   #50
OHIO SPEED
OHIO SPEED's Avatar
WOW looks great ColbySS!
Thanks again!
Old 01-03-2014, 09:19 PM   #51
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Please on me price on all 3 options.
Thanks!
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 01-07-2014, 06:59 PM   #52
melbourne_ls1
melbourne_ls1's Avatar
Drives: 2011 2SS Red Jewel Tintcoat Vert
Please PM me a price on all 3 options to 32940.
Thanks!
melbourne_ls1 is offline   Reply With Quote
Old 01-08-2014, 04:20 PM   #53
OHIO SPEED
OHIO SPEED's Avatar
Arrow BC Racing/MEGAN Coilovers for Sale FREE S/H
BC Racing ER Series Coilovers are now available at Ohio-Speed
Old 01-16-2014, 04:45 PM   #54
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
price on megan racing thanks!
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 01-19-2014, 11:49 AM   #55
OHIO SPEED
OHIO SPEED's Avatar
Our car on Megans Street Series, 22" wheels with 1-1/2 drop all the way around
PM for our low prices!
Old 01-20-2014, 03:58 PM   #56
OHIO SPEED
OHIO SPEED's Avatar
Our sale continues with the best pricing and free s/h!
camaro, coilovers, lowering kit, springs, suspension
