Anthony @ LG Motorsports
Old 07-20-2013, 01:03 PM   #281
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
If it can indeed be made to work on a G8 fairly easily, I think I'm in.
Unavowed is offline   Reply With Quote
Old 07-20-2013, 02:24 PM   #282
ramsman34
ramsman34's Avatar
Drives: 2011 Summit White, 2SS/RS-LS3
Are you going to buy a clutch and fuel system and a bunch of other parts too? The kit is no where near 10k.
Well,
70K miles on the LS3 right now (so would discuss beefing up the bottom end) - I have to pay for the kit, the removal of my CAI, LTs, then would want to coat my OEM exhaust manifolds....I'm not doing the install so pay for that and the tune, then while he 's in there, upgrade the fuel system, add a cam, add gauges & poss. boost controller, then yes - look at a Mantic clutch, then the drive line and rear axle...crap - now I want to finish the suspension (just upgraded bushings when I did the LT's), so Pfadt coil-overs, etc. to keep the car stuck while I blast through canyons....
....so, there is my $10, possibly $13K
But DAAAAAMN it will be fun when I can pull it off!!!1
414whp, 403wtq (Mustang Dyno) -Thanks Ray/Full Throttle Kustomz
ramsman34 is offline   Reply With Quote
Old 07-23-2013, 09:47 AM   #283
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
The only issues with the G8 fitment is that the bumper area is different than the Camaros... It will definitely require some custom tubing going into the bumper area, and I'd definitely check the icooler fitment too.
Matt @ FSP is offline   Reply With Quote
Old 07-23-2013, 10:21 AM   #284
Unreal
Drives: 2006 Z06
There is no way the complete kit bolts onto a g8, but if the turbo adapters fit and turbos are in a good place then fabbing up cold side piping is easy and any decent fab shop or shop that can weld could do that. I know AGP isn't going to pursue the work to do a full g8 kit just because of the lack of demand.
Nick
Corvette Z06 -1200ish rwhp
Old 07-28-2013, 05:13 PM   #285
2ss-booya
2ss-booya's Avatar
Drives: 2015 SS Sedan M6
this kit should work with the zl1 correct?
2ss-booya is offline   Reply With Quote
Old 07-28-2013, 06:02 PM   #286
Unreal
Drives: 2006 Z06
Mostly. I would call the shop or talk with Matt@FSP, or Andy@ADM. It could be made tow work but some piping would need to be tweaked for the different TB location at the minimum. Turbos/etc should bolt on no issues.
Nick
Old 07-28-2013, 06:14 PM   #287
grocerygetter
instigator
grocerygetter's Avatar
And again the ZL1 inter cooler adjustments...less involved than g8...but still
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 07-28-2013, 08:04 PM   #288
GLGJR
Drives: 09 CTS-V
Call Andy. I don't think the down pipes for the turbos will fit the ZL1 exhaust manifolds. I believe he tried a set but your best bet is to call him.
GLGJR is offline   Reply With Quote
Old 07-28-2013, 08:09 PM   #289
Unreal
Drives: 2006 Z06
Worst case would have to swap to the SS manifolds if that is the case.
Nick
Old 07-28-2013, 08:32 PM   #290
SGDM
SGDM's Avatar
Drives: 2016 2SS
Man...that is a slick kit. Gonna have ADM install one on my '14 1LE when it arrives. What are they using to coat the manifolds?
Who Dares...Wins
ADM Performance Built LT4 SC
SGDM is offline   Reply With Quote
Old 07-28-2013, 08:47 PM   #291
Unreal
Drives: 2006 Z06
Local place does good ceramic coating. Makes a world of difference. Keeps everything cool in the engine bay and keeps the heat into the turbos so they spool quick/etc.
Nick
Old 07-28-2013, 09:38 PM   #292
ADM PERFORMANCE
Drives: 2016 CAMARO SS
ZL1 Manifolds
Cast stainless ZL1 Manifolds do not have the same groove in them like the SS
manifolds.We plan on Machining them in the future..Near future
ADM PERFORMANCE is offline   Reply With Quote
Old 07-28-2013, 09:39 PM   #293
ADM PERFORMANCE
We prefer raw parts as we have our own coating just down the street with our own color combo's.
Old 07-28-2013, 09:47 PM   #294
SGDM
SGDM's Avatar
Drives: 2016 2SS
Thanks Andy. Should have known that...
Who Dares...Wins
