Cold Air Inductions
Old 04-19-2013, 05:03 PM   #43
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
The FMIC is really big.. We'll be doing testing without and with methanol also to see what additional IAT's we can control since we are down here in the FL heat!
Matt @ FSP is offline   Reply With Quote
Old 04-19-2013, 06:01 PM   #44
The Baron
The Baron's Avatar
Drives: 2013 zl1
you guys should give me a pm after you decide weather you would like to try putting this on a ctsv coupe that already has a ls9 cam in it....hint hint...
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 04-20-2013, 05:22 AM   #45
Shooter_X
Shooter_X's Avatar
Drives: 2011 Black 2SS 6MT
I'm mostly sold. What supporting fuel system needs are there? The booster pump or replacement unit? I am still not sure how I feel about the booster pumps. I'm assuming changing injectors is a given.
Shooter_X is offline   Reply With Quote
Old 04-20-2013, 11:36 AM   #46
Unreal
Drives: 2006 Z06
Kit comes with injectors tuner etc. Of course that can be customized. It all depends on how much power you want to make.
Nick
Corvette Z06 -1200ish rwhp
Old 04-20-2013, 11:38 AM   #47
Unreal
Drives: 2006 Z06
I saw two turbos with another shops name on them on the shelf yesterday. I want to see what that does but can't ruin the surprise.
Nick
Old 04-20-2013, 11:59 AM   #48
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Motion427 is offline   Reply With Quote
Old 04-20-2013, 12:42 PM   #49
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Originally Posted by Motion427 View Post
ADM PERFORMANCE is offline   Reply With Quote
Old 04-20-2013, 01:27 PM   #50
Motion427
Stupid question.
Can I guy run hi flow cats after the turbos for emission reasons or for state inspection?(low boost or a drive with grandma).
Then built a second set of off road connection pipes when you stay at your local state and play at the track?
Should have some room between the turbo and the x-pipe,you would think........
Old 04-20-2013, 01:49 PM   #51
Matt @ FSP
Matt @ FSP's Avatar
Stupid question.
Sure why not... Just watch the heat with what cats you do use. A lot of the aftermarket high-flow cats are no where near the reliability/build quality of the factory cats, just a FYI.
We have had much success with the ARH high-flow cats on high boost applications, you may consider to use them.
Old 04-22-2013, 08:31 PM   #52
ADM PERFORMANCE
Old 04-22-2013, 09:00 PM   #53
Ryne @ CMS
Ryne @ CMS's Avatar
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra
ARH cats are tough, so are the kooks greens... but $$$
Ryne @ CMS is offline   Reply With Quote
Old 04-22-2013, 10:55 PM   #54
Unreal
Drives: 2006 Z06
Easy to swap housings. Can do .82s or bigger. That being said, the turbos that come with the kit make 550rwhp all the time on evos/srts and other cars. So two of them should be able to make 1000hp pretty easy. If not putting bigger is very easy.
Nick
Old 04-23-2013, 04:49 AM   #55
killmode_on
Drives: 2011 2SS/RS
Originally Posted by bigbirdws6 View Post
2.0L vs a 3.1L (half of a 6.2L)
mean you have 33% more exhuast gas in the 3.1 over the 2.0. thats alot more back pressure.....
time will tell just saying because it worked in a smaller motor doesnt mean it will work in another.
besides go to a 427. thats 3.5L. thats DAM NEAR twice the exhaust gas as the little 2.0 evo.
Not really how it works. 2.0L 4-valve per cyl. reving to 9000rpm is the key thing you are missing. The easier way to look at it is just simple HP. Engine is an air pump, Xlb/min of airflow makes roughly Xhp no matter what the static displacement is. Bigger displacement engine doesn't equate exactly to more air thoughput. At 50lb/min of throughput per turbo, the .63's are at about 1.4 pressure ratio. Not bad for a street car but a race car doesn't need that quick of spool up.
That being said you are right that the .63's are on the small side. FSP was only sent them for back to back testing with .82's.
1.0 and 1.25 housings are available and interchangeable.
Be vewy vewy quiet, I'm hunting GT500's.
killmode_on is offline   Reply With Quote
Old 04-26-2013, 06:53 PM   #56
Matt @ FSP
Matt @ FSP's Avatar
So... We are putting a set of AGP's on a stock cubic inch motor in the next coming weeks. Looks like the shop car will be the SECOND FSP car with the AGP TT kit on it!
- Matt
