Old 04-19-2013, 12:02 PM   #15
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15 STI, EB Expy,'10 2SS/RS M6, KB1
Originally Posted by rforbes View Post
This is the setup I have and with a good tune is perfectly safe. All things being relative.
OP talked about using a canned tune, not a custom tune till the bigger shot. I'll agree that with a good tune, it should be fine. But I like having some safe guards to help as much as possible.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 04-19-2013, 12:17 PM   #16
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
Here is the bottle in the trunk, Just put it in. Thanks for the replies. I know and feel your concern for safety. And its not that I want to take stupid chances, I have talked around with people and shops. Like I stated earlier, it wasnt my intention to have an import guy advise me on my NOS setup. But I have went to him before when I had my turbo 4 banger and he never steered me wrong. and if you really think about it....LOL.....this guy has seen alot of "chances" taken with nitrous dry systems, AKA the stock civic guy coming in with self installed 200 dry shot wanting to beat a camaro, mustang, challenger like in the movies. So we are working towards safety in this. Keep you posted feel free to chime in with more good advice. Thanks.
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
Old 04-19-2013, 12:20 PM   #17
05SilverStreak
Old 04-19-2013, 12:30 PM   #18
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Originally Posted by 05SilverStreak View Post
Well, I am counting on the MAF to add fuel as well as 02 sensors. That is the way system is designed. I understand what you guys are saying though, thats why I am asking before spraying. Kit instructions say as long as adequate octane booster or race fuel is used, (not necesarily 100 percent), that it would be safe to spray up to 100 with no timing retard. 150 shot would require at least 2 degrees of pull. I dont think I am going to even try the small jet, (75), without first getting a A/F guage. they say the placement of the dry nozzle is key as the sustem works by the MAF picking up the shot, so I am going to position it to spray all aver it. Thing is I will have to mount the jet at the end of the air filter so the MAF will see it. K&N intake has the MAF mounted all the way to the filter end so no room to mount it for the MAF to see it. Will post a pic in a few.
Yes, get a wide band. Your O2 sensors will do nothing for you at wot. Wot is open loop.
If your canned tune is adding timing and now your spraying in your intake tube, your iat sensor is going to read a colder temp and will most likely want to add more timing. But if they designed the kit to work by spraying across the maf, then I can't argue that point.
Old 04-19-2013, 02:03 PM   #19
05SilverStreak
Yes, the instructions said spraying cold nitrous across the MAF would drive the MAF nuts and add lots of fuel, thus creating the horsepower increase according to how much nitrous the MAF saw. So I mounted some of the kit today, now Im gonna have beers and tacos and get back to it tomorrow. Thanks for the input.
Old 04-21-2013, 05:13 PM   #20
05SilverStreak
How about this? If I was to transform this to a wet kit right away, all I would have to do is run the fuel line off the stock pump to the plate behind the throttle body right? (Assuming of course I had one to put there). After that if I am correct in my thinking its just run the nitrous line and the fuel line to the plate and Im good? I could probably at that that point change the tune or retard the timing myself 2 degrees and run the 150 shot. Just thinking out loud. Anyone got pics of how they ran the fuel line off the stock pump?
Old 04-21-2013, 07:20 PM   #21
Thebabycheech2012
Thebabycheech2012's Avatar
Drives: 2010 ss2 l99
I'm looking to do a nos kit as far as wet or dry I don't know I a aem air intake and a diablo tune on 91 I have a lot of questions since I have an L99 but I'm not looking to blow a ring
Thebabycheech2012 is offline   Reply With Quote
Old 04-22-2013, 03:04 AM   #22
05SilverStreak
Im in the same boat. Hopefully as this thread progresses we will both learn more about it. Good responses and help so far.
Old 04-22-2013, 06:40 AM   #23
Badbubba
GrINned & JUICEd
Badbubba's Avatar
http://www.camaro5.com/forums/showthread.php?t=217103
Are you changing your plugs too?
Old 04-22-2013, 07:01 AM   #24
Thebabycheech2012
Originally Posted by Badbubba View Post
Thank you I'm looking into it
Old 04-23-2013, 12:04 AM   #25
05SilverStreak
Yes, from what I have been reading and what shop guy was saying. I would be ok on the stock type plug, (maybe a better quality one but same heat rating), up to a 75 shot. From 100 to 150, (150 is all I plan to go to), one step colder good quality plug would be needed. Once I get all installed I will be trying the 50 and 75 out on stock plug with no timing retard yet. Everything I read and what the tuner shop guy was saying jives with that, even with canned tune. And before the flaming starts, I have worked with this guy before and he has seen his fair shair of nitrous mistakes. AKA the stock civic guy trying to spray 200 dry to keep up with the big cars. So a little trust I am giving to him. I just dont know if higher than 91 octane fuel would be needed at 75, Im not worried about it at 50 but if it pings I gues ill know.....
Old 04-23-2013, 08:20 AM   #26
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Here is the suggested breakdown:
NGK Plug Part# = Shot Size
B6EFS(1 Step Colder) 3177 = 0-75
BR7EF(2 Steps Colder) 3346 = 75-150
B8EFS(3 Steps Colder) 1049 = 150-225
B9EFS(4 Steps Colder) 1085 = 225-300
Also recommended is to pull 2* per 50hp.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 04-23-2013, 11:02 AM   #27
BplumCrazy-SS
BplumCrazy-SS's Avatar
Drives: 416 w/TH400
are people spraying through the shift?
BplumCrazy-SS is offline   Reply With Quote
Old 04-23-2013, 11:27 AM   #28
05SilverStreak
Auto trans here, no worry about the shift. But WOT activated systems disengauge when you let off the throttle to shift. If you WOT shift....you could be at risk.
