JUICEDMOTORSPORTS
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 04-11-2013, 11:44 PM   #1
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
2012 v6 Convertible vs 2012 Challenger?
WHO WINS both Auto's
skipinminn is offline   Reply With Quote
Old 04-12-2013, 12:07 AM   #2
Mike-D
HTFU
Mike-D's Avatar
Drives: 2SS/RS
R/T challenger, wins. V6 Challenger, toss up
Mike-D is offline   Reply With Quote
Old 04-12-2013, 11:08 AM   #3
Stew
Drives: 92 Luminadead/01 Dakota/97 F150 4x4
yep
Stew is offline   Reply With Quote
Old 04-13-2013, 10:30 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
V6 chally (or r/t for that matter) is very very poor in the corners and the 3.6 pentastar is ok ish but your still stuck with the 5speed auto only, work at a jeep Chrysler dodge fiat dealer so I get to drive alot of everything
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 04-14-2013, 10:49 AM   #5
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Chally weighs ~3,800 with 304 HP, V6 Vert comes in around ~4,000 with 320 HP. You really couldn't make it more even if you wanted to. Really going to be up to the drivers, whoever leaves first will probably win. Only disadvantage for the Chally might be the 5 speed and I think they come with 235-18s which are somehow worse than the 245 Goodrichs that the Camaro comes with. Looks like you have the 19s though with the Pirellis so you have the tire advantage for sure.
Leave first and you'll probably win.
DarkneSS is offline   Reply With Quote
Old 04-15-2013, 10:37 AM   #6
Stew
Wow, discussion had nothing to do with corners and you may want to check the 11+ models, they do handle well and they offer the Super track Pak and for the R/T and the SuperSport group for the v6 which makes them handle even better. 3.6 pentastar cars have hid mid/low 14s stock which is right there with the pack considering it just has the automatic available. As for the automatic, it may be an older design, but there is really nothing wrong with it. Yes the 8 speed is better, but when it comes to straightline performance, it seems to work extremely well, IE the SRT 392s that run 12.2 with the "old 5 speed"
Old 04-16-2013, 12:32 AM   #7
xstuntman
Drives: 2012 2LS Camaro LFX
Six Challenger does 0-60 in 6.3 seconds.
LFX does 0-60 in 5.9 seconds.
Winner - Camaro
xstuntman is offline   Reply With Quote
Old 04-16-2013, 10:29 AM   #8
Stew
Winner - Camaro
Coupe yes, convertible is around 300-400 pounds hevier so, um, no.
http://www.motortrend.com/roadtests/...le_first_test/
2012 convertible: 0-60 in 6.6 and 1/4 mile in 14.9@94.7 with the 6 speed automatic
3
http://www.motortrend.com/roadtests/...n/viewall.html
12 Challenger 0-60 6.4 and 1/4 mile in 14.8@94.8, keeping in mind the V6 manual Camaro in that test could only hit 14.5@98.2
