Old 06-23-2009, 01:57 AM   #1
Adam
You Said Member
Drives: 2010 SIM 2LT Auto RS
subwoofer interfering with radio reception.
Local radio, not xm.
Anyone else experience this? When I first got the car, I got a lot of stations decently, now with the sub installed, I get only a few of the stronger ones, and the ones that no longer come in make a really weird noise, not like regular white noise.
It's not a huge deal, but has got me curious.
Adam is offline   Reply With Quote
Old 06-23-2009, 06:57 AM   #2
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
The antenna is in the back window,so if the subwoofer is vibrating the glass it very well could affect the FM reception.Also if the amp or power cable for the amp is near it,it could cause some induction.
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 06-23-2009, 10:34 AM   #3
GothamCamaro
Then you're gonna love me
GothamCamaro's Avatar
Drives: 2010 Black Camaro Tumbler RS
That's interesting. Guess I won't worry about it, I'll be using XM, I think the last time I had the local radio on was 4 years ago.
Own- "Does it come in Black?" Exterior/ Grey Interior 2LT/RS Automatic
_____________________________________
The Batman would only drive a 2010 Camaro and buy from Camaro Scotty. 'Nuff said.
Anyone that knows of a place that is making the Concept Shifter for the new Camaro. (Auto specifically) Please let me know.
Order# NDTMVP Ordered 10/23/08.
2000 on 5/21/09... It begins.....
4B00 on 6/26/09... In transit to the Cave
5000 on 7/6/09 it waits for my arrival!
1000000 on 7/10/09 The Tumbler is in the Cave!
GothamCamaro is offline   Reply With Quote
Old 06-23-2009, 11:01 AM   #4
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Did you get your windows tinted also? Metallic window tint can interfere with the FM antenna reception.
Did you do the sub install or did someone else do it? You might want to check around under the rear window and see if they/you accidentally knocked the antenna connection loose during the sub install.
rolnslo is offline   Reply With Quote
Old 06-23-2009, 11:02 AM   #5
CamaroFan1
CamaroFan1's Avatar
Drives: Camaro
I've seen something similiar before. You probably put in another amp for the sub. Make sure it is grounded properly.
CamaroFan1 is offline   Reply With Quote
Old 06-24-2009, 11:06 PM   #6
Adam
You Said Member
It's grounded properly, no window tinting, installed it myself. If I somehow knocked the antenna cable loose, I wouldn't even know where it's at to look.
It's not shaking the glass during testing, it's at low volume and it's not like there's much bass coming over the radio.
I have tested, and the interference gets worse when the sub comes on, I can test this easily since the sub uses signal sensing to turn on.
It's like it's trying to lock onto certain signals, and can't. Some signals are automatic, but there's one in particular I'd like to get and it's from a station probably 90 miles away and goes out only when the sub is on. There are likely others, but that one interested me the most.
edit: it's because I have a class D amp, does mode switching or something like that, causes RF interference, it's a jl 250 watt amp, anyone know of an easy fix?
Old 06-25-2009, 01:34 PM   #7
shevyman
Drives: 2010 Camaro SS IOM
you may have wired something wrong. send pics of your job.
shevyman is offline   Reply With Quote
Old 06-25-2009, 01:42 PM   #8
shevyman
another thing it could be a problem with your fm tuner. disconnect the sub and see if it still happens, what wires did you tap into and what signals did you get. if that amp has signal sensing you have to make sure its getting the right signal from the stock amp. the factory amp is located behind driver side rear bumper. have you messed with it.
Old 06-25-2009, 01:42 PM   #9
shevyman
so you used a hi low converter right?
Old 06-25-2009, 01:50 PM   #10
Vash
Drives: 00 Blazer
Where are you pulling power from? Run a fused line direct from the battery to a power distribution block then amp. Might want to try a capacitor as well.
Old 06-25-2009, 02:19 PM   #11
AhX
AhX's Avatar
Drives: 2010 2SS IOM\IOM
Bad ground
AhX is offline   Reply With Quote
Old 06-25-2009, 03:09 PM   #12
InfernoFlame
SUPRMNN
InfernoFlame's Avatar
Drives: 2010 SS/RS IOM/IOM
I agree with the bad ground...
InfernoFlame is offline   Reply With Quote
Old 06-25-2009, 04:34 PM   #13
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
Put a 0.1uF ( 20V or greater cap ) 12V to ground on your amp. Also clip ferrite beads to ALL wires connected to your amp.
This MAY fix it. The amp may have a problem, as it should not generate RFI if it is designed properly.
Re-check your grounds. The amp should be screwed to the metal of the car.
patriotpa is offline   Reply With Quote
Old 06-25-2009, 09:38 PM   #14
Adam
You Said Member
I don't know what a 0.1uf whatever is.
The ground is good, trust me.
Class D amps are known to cause this sort of thing, at least that's what I've read, google it if you want.
Keep in mind the amp is right below the rear window, where the antenna is located, which is probably why other people with class D's don't notice it.
The only good tip so far is the ferrite clips, though if you could be more specific about which wires, power, ground, rca, and speaker?
HD Radio? rolnslo Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 37 08-19-2010 04:07 PM
Potential Solutions to Radio Problems The_Blur Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 17 11-10-2009 10:23 PM
sorry to cross post but need someone who can get onto chevylaunch.com Adam Camaro Price | Ordering | Tracking | Dealers Discussions 7 06-04-2009 04:40 PM
Replacing Camaro's funny radio camaromaybe 5th Gen Camaro SS LS LT General Discussions 15 02-18-2009 11:51 AM
Sirius XM Radio drummerstevey Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 08-04-2008 09:12 PM
