Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 04-12-2013, 07:29 PM   #1
Drives: Cammed
Tuning shift point question?
I have a A6 2SS/RS it is cammed, dod delete, headers, 3inch exhaust, Cai, tune, 100 shot of nos. I was reading some forums and it said that sports mode shifts at a higher point. My car is tuned to shift at 6,800 rpm. Now when I'm in drive or manual mode it shifts at 6,800, but when I'm in sport mode it looks like it shifts at 5,700. And for all the attempts i was in competitive mode and traction control off. Is this possibly because they didn't change the shift point on sport mode to shift higher? I'm thinking drive and sport modes shift point has to separate tuning. I'm know nothing about tuning but I can fix engine problems. Can someone help. I know how to drive my car but i just started looking at this because I never did dead stop races because I had horrible tires I would only race rolls and use the paddle shifters. But now I have sticky tires
Randyscamaro2010 is offline   Reply With Quote
Old 04-12-2013, 10:37 PM   #2
grocerygetter's Avatar
Drive should shift at a lower mph then sport. 6L80 TCM doesn't ref uses wheels speed. At least that is how most tuners do it.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 04-13-2013, 07:52 PM   #3
Tampa Tuning
What your tuner should have done while collecting information from the dyno tool is determine where your cam HP levels start to plain or drop off, and command a shift point shortly there after. That will allow you to continue to stay in the power band at shift points.
Guys tend to disable all torque management. If your tuner knows how to use it properly, it can actually help your shifting. The key is understand it properly.
Tampa Tuning is offline   Reply With Quote
Old 04-16-2013, 09:12 AM   #4
Drives: 2010 IOM RSS
There are separate shift speed tables for sport mode. It sounds like he may have just forgotten it. You may need to call him and ask him about it.
Torque management is a very important part in how these transmissions behave.
Alvin@PCMofNC is offline   Reply With Quote
Old 04-18-2013, 04:33 PM   #5
Drives: Cammed
Thank you for the information I really appreciate it
