JDP Motorsports
Old 04-12-2013, 10:28 PM   #1
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
DIY: V6 rotors & brakes
OK Guys! easy with my English...
Here we go:
Tools i use:
socket wrench braker
1/2" socket wrench
14,16,18mm socket
hammer
screwdriver
T30 Torx bit
piece of hanger
disc brake pad spreader
WD-40
1) remove cap from master cilinder
2) lift car,remove tires
3) remove caliper bolts(2) using 14mm socket
4) remove caliper & pads (use piece of hanger to hanged on spring to protect brake line)
5) remove caliper holder bolts (2) using 18mm socket
Note: back caliper holder bolts need 16mm socket
6) push back pistons using brake pad spreader
7) remove T30 torx bolt from rotor and remove rotor (i have to hit it with hammer on center to loose it up)
Note: back rotors need to disengage E-brake to remove
install new rotors, install everything back... took me 2 1/2 hours by myself...
Tip: use WD-40 before remove T30 torx bolt and rotors to loose them up from rust...
Monchy36 is offline   Reply With Quote
Old 04-12-2013, 10:35 PM   #2
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
What pads and rotors did you use?
Have you used them hard enough to feel any difference?
Macrackie is offline   Reply With Quote
Old 04-12-2013, 10:39 PM   #3
Monchy36
Monchy36's Avatar
give it a little test and feel a lot better! i let you know tomorrow...
Old 04-12-2013, 10:54 PM   #4
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
What is the diff between the caliber holder bolts and the caliber bolts?
kjkjr27 is offline   Reply With Quote
Old 04-12-2013, 10:56 PM   #5
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
BTW looks good
Old 04-12-2013, 11:00 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Looks great. have you driven it yet?
Proud owner of litho #179 Click Picture for Build Thread
Old 04-12-2013, 11:06 PM   #7
chicagobulls
one car wolfpack
chicagobulls's Avatar
Drives: 2010 Camaro V6
Nice
chicagobulls is offline   Reply With Quote
Old 04-13-2013, 05:53 AM   #8
Monchy36
Monchy36's Avatar
Caliber bolts are 14mm you remove them to remove brake pads first and get access to push back pistons, caliber holder bolts are 18mm front, 16mm back you need to remove this so you remove rotors...
Old 04-13-2013, 05:54 AM   #9
Monchy36
Monchy36's Avatar
Give a good drive to work and feel amazing! Braking is so much better! I'm really glad that I did it!
Old 04-13-2013, 05:55 AM   #10
Monchy36
Monchy36's Avatar
Originally Posted by chicagobulls View Post
Nice
Old 04-13-2013, 01:14 PM   #11
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Looks like I may have to make yet another trip to lowes to buy more sockets...shoulda just bought a huge starter back haha but at this point it would be pointless . I do have a little kit for like 6mm to 12mm haha!
Old 04-13-2013, 01:52 PM   #12
2010camarolt
2010camarolt's Avatar
Drives: Victory Red 1LT
good work monchy! going to bookmark this for the future!
2010camarolt is offline   Reply With Quote
Old 04-13-2013, 02:01 PM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Great job on the write up. This is on my list of things to do once I need a new set of brakes. Not sure when that will be, at my current highway driving habit, might be a few years yet.
Old 04-13-2013, 02:23 PM   #14
Monchy36
Monchy36's Avatar
Just go to Sears they have a special on craftsmen tools...
PS: the brake pad spreader is very handy! Only cost $8 on AutoZone...
