Cold Air Inductions
Old 04-13-2013, 12:49 AM   #1
11Huggerwhite
11Huggerwhite's Avatar
Drives: 2013 Camaro SS supercharged
Finally done
Finally got the TVS2300 installed and running. It's being flat bedded to my tuner on Monday, I can't wait to be able to go do some highway pulls. How much rwhp do you think I'll hit with these mods?
TVS2300 S/C stock pulley (new style blower)
TSP 2" long Tube headers high flow cats
TSP 235/239.639"/623 Camshaft
SLP Blackwing intake
ALKY Dual Nozzle Meth kit
ZL1 Fuel Pump
Kenne Bell Boost a pump
FAST 65lb injectors.
Thanks! Will post some videos when I get the car back next week.
11Huggerwhite is offline
Old 04-13-2013, 12:51 AM   #2
Nice, I'll be watching for the videos
2010 SSRS is offline
Old 04-13-2013, 01:02 AM   #3
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Probably around 600 to the tire I'd guess
I Ain't About That Stock Life.
2SS45th is offline
Old 04-13-2013, 01:07 AM   #4
11Huggerwhite
That's about what I thought.
Old 04-15-2013, 12:55 AM   #5
11Huggerwhite
Bump
Old 04-15-2013, 08:29 AM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I would say around 550 to 575 with the stock pulley.
MODS:
10aSSee D is offline
Old 04-15-2013, 08:32 AM   #7
10aSSee D
10aSSee D's Avatar
Just re-read the post and seen the meth part, maybe 600.
MODS:
Old 04-15-2013, 08:45 AM   #8
old motorhead
Drives: Maggie blown LS3 vette
You need to go ahead and find you a smaller blower pulley before the tune. The way you're set up, you won't see much over 5psi with a 3.8" pulley.
old motorhead is offline
Old 04-15-2013, 09:05 AM   #9
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
True, but the OP never mentioned any power goals. I was going to go with a smaller pulley also, but was happy with my numbers and the performance. I'll pulley down when I get bored again.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline
Old 04-15-2013, 12:29 PM   #10
11Huggerwhite
I have the new pulley the 91mm. I want to see what it puts down first and then pulley down when I get all the driveline and clutch mods done to handle the power.
Old 04-15-2013, 12:44 PM   #11
old motorhead
That's a little less than 3.6". That should be good for a little more boost. You won't be too far from 600 on 93 octane and if tuned for the meth. Should be a whole lot of fun
Old 04-15-2013, 12:56 PM   #12
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
Your shop will love the way you think...pay for a dyno, take it for a ride, buy some parts/install, pay for another dyno...rinse and repeat. I did the same thing. Would have saved a lot of money if I would have just set an initial goal and did it all at once....either way you end up happy, one way just leaves you with more money in your pocket (to buy more mods) haha!
S-eatin-grin is offline
Old 04-15-2013, 01:28 PM   #13
fldrummer
"Black Ace"
fldrummer's Avatar
That is also true, to a point (depends a lot on your relationship with your shop )... I could've done the stock pulley to see what it put down, then swapped to a smaller pulley immediately afterwards and retune--for little more than the cost of the pulley. However, I was not in a rush to push it too far, as I don't want to buy DRs, new clutch, axles, etc. too soon. When I pay down what I have done now, I'll consider upping the ante some more.
Old 04-15-2013, 01:33 PM   #14
11Huggerwhite
575-620rwhp is what my tuner is thinking. He also said to not pulley down till I replace the clutch and diff so I don't blow them. I know I will want my HP but I'll probably build and forge the motor before I go crazy. 575-610 is plenty for the street anyways.
