Solo Performance
Old 04-14-2013, 09:56 PM   #15
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
I bought two of them at my local dealer for $50 apiece. I had to show them my drivers license and registration to prove it was my car. They ordered them using my VIN and they came in a few days, pre-cut. I programmed them myself through the DIC. It was a very easy procedure.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 04-14-2013, 09:59 PM   #16
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I just bought a replacement key, lost my 1st one. Cost me 75$. Another 25$ to get it "programmed" once it arrives.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan coil overs, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Dynamat, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-14-2013, 10:02 PM   #17
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Yes... mine did that.
Even before that, mine was coming apart... and I wrote a DIY. Here is a fix:
http://www.camaro5.com/forums/showthread.php?t=186597
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 04-14-2013, 10:03 PM   #18
Bell040
Bell040's Avatar
All you do is plug it in the ignition and it programs itself. I did this last month. The DIC reads "3 keys programmed".
Ordered: 10-13-08
Recieved: 6-12-09
Old 04-14-2013, 10:10 PM   #19
Hyena
Drives: 2013 1LT RS CRT
any dealer can get you a new key.you'll have to provide proff of ownership(photo id and either registr,ins car or title with your name and VIN on it).if they have the right type of key cutter they can cut the key in as little as 2 min...or they can order it pre-cut from GM.that type of remote/key is cheaper if the dealer cuts it(between 40-50.) or somewhere about an extra 10-15 for a pre-cut.
make sure you bring in your existing key so they can trace the key cuts,otherwise,they will try to charge you for getting the key code from GM.
Hyena is offline   Reply With Quote
Old 04-14-2013, 10:15 PM   #20
hysonmb
hysonmb's Avatar
Drives: 2010 2SS / RS
I bought my car used and whoever had it before me had dogs or some very badly tempered pet that chewed on the keys. I bought a replacement fob on ebay for about $30, swapped the blank blade for the cut one, and spent a couple of seconds to reprogram. It's very easy to do and saves you time of having wait for the dealer do it.
hysonmb is offline   Reply With Quote
Old 04-14-2013, 10:18 PM   #21
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Put a programmed fob in first. Then quickly take it out and put in the new fob!!
A Valet service lost my keys one day!! It was $135 and some change to get a new one!! Valet paid for the lost fob!!
Hope you can get on cheap!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 04-14-2013, 11:08 PM   #22
01pewterz28
Camaro Junkie
01pewterz28's Avatar
Yep happened to mine
*Delivered 4/13/17*
Old 04-15-2013, 06:43 AM   #23
jd10013
Drives: 2012 camaro
Originally Posted by Cam2011 View Post
Nope, and I checked mine, and would guess that the ones with the autostart on them are different in more ways than just having an extra button. On yours I see a slight indentation under the icons that would prove to be a weak spot, on mine there is no such indentation, except for maybe a slight one at the panic button.
I just looked at mine too, and there are no raised bumps on the buttons either. not even the panic one. maybe because it's a 2002
jd10013 is offline   Reply With Quote
Old 04-15-2013, 08:14 AM   #24
solteroblues
solteroblues's Avatar
Drives: 2011 Camaro LS IBM
when I bought mine used (only 24k miles), one of the remotes had done that. I took it to the dealer (the dealer I bought it from never even let on like it could be replaced, I figured the previous owner just ruined it on purpose until I saw here where others had it happen to them) and got a free replacement under warranty. They told me that someone had been using their nails to open it. I told them I had seen other people have the same problem and they denied that was possible for it to just happen, but replaced it anyway.
solteroblues is offline   Reply With Quote
Old 04-15-2013, 03:50 PM   #25
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
this
Old 04-15-2013, 04:24 PM   #26
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Originally Posted by trooper182 View Post
So was washing the car today and went to unlock the doors and when I pushed the unlock button this happened. Kinda sucks but I will just switch to my spare key. Button still works. Anyone know how much a new key fob will cost?
The MSRP for the fob you posted a pic of is $40. This price is for a cut key to your vin directly from GM, not just the fob itself. If a dealer wants to charge more than that walk away. You can order one online and just pay the extra for s/h.
Also don't pay to have it programmed. You can program it yourself in less then 10 seconds.
Old 04-17-2013, 08:50 PM   #27
cmb74656
cmb74656's Avatar
Drives: 2011 Camaro 2SS/RS CGM/BLI A6
Valet? No way!
Dan Wheldon (1978-2011)
MODS: RX Performance catch can, Jegs CAI, ZL1 grille, chrome license plate frame, GM locking gas cap, Defender Worx chrome DRL bezels, GM molded splash guards, Oracle LED side markers, DRLs, tag lights and reverse lamps, Technostalgia Rapid Fire tail lamps, Vitesse shift paddle extenders, MBRP cat back.
FUTURE: long tube headers, front splitter, slotted/drilled rotors, leather console and e-brake handle boot, remote fuel door and rear seat release, sway bars and bushings.
WISH LIST: Edelbrock E-Force SC, LS3 conversion
cmb74656 is offline   Reply With Quote
Old 04-17-2013, 10:56 PM   #28
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Yeah I'd be upset at least it wasn't the engine
White shoes at the black show
AmericanMuscleCars is offline   Reply With Quote
