Gen5DIY
Old 06-23-2009, 12:46 PM   #1
ittybittyfds
ittybittyfds's Avatar
Drives: 2013 Victory Red ZL1 M6 #495
"6-Speed manual" 1st to 4th shift
Can anybody tell me what the purpose of the 1st to 4th gear shift is?
it seems the trans only does it at certain time and i really dont understand what the purpose is for?
2013 Victory Red ZL1 M6, Roto-Fab CAI,
ittybittyfds is offline   Reply With Quote
Old 06-23-2009, 12:48 PM   #2
ProchargedSS
ProchargedSS's Avatar
Drives: 2014 ZL1 SIM
I've never heard a "good" explanation. Just buy a skip shift eliminator and be done with it.
ProchargedSS is offline   Reply With Quote
Old 06-23-2009, 12:49 PM   #3
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
If you are driving normal it skips to 4th to save gas.
If you are getting on it, its normal shift.
5.1) What is CAGS?
Computer aided gear selection is a hack that was invented to help raise fuel mileage ratings. It is implemented with a computer controlled solenoid that is used to lock out second and third gears. The system "kicks" in when the following conditions are met:
Engine coolant is 170° F or higher
Speed between 15 and 20 MPH
Throttle between 0 and 35%
During the lockout, a dashboard light that says "SKIP SHIFT" is illuminated and you are supposed to shift from 1st directly to 4th. There is apparently no timeout; that is, the lockout continues as long as the above conditions persist.
5.2) How can I defeat CAGS?
Prior to 1996 when OBD-II went into effect, one could simply unplug the CAGS solenoid connector to defeat it.
OBD-II is required to detect failures that impact emissions, so disconnecting the CAGS solenoid on a 1996 or newer T56 transmission car will cause a Service Emissions System (SES) warning light. A number of companies (including Chevrolet) sell !CAGS kits. The kit consists of a connector with 24 ohm resistor potted in it that simulates the electrical load of the solenoid.
A cheap alternative to the !CAGS kit is to insert an appropriately valued 1/2 watt resistor into the wiring harness connector and taping it up with electrical tape.
5.3) Where did the RPO MN6 transmission come from?
The T56 six speed manual transmission came from the 1989 Corvette ZR1 package. It was manufactured by Borg-Warner until they sold their transmission business in 1998. Tremec now builds the T56 in Mexico.
5.4) What is the difference between the Hurst factory and aftermarket shifters?
The optional Hurst factory shifter is laser cut from a stamped steel stock. The shift lever has a rubber isolator to reduces noise and vibration. The Hurst Billet Plus aftermarket shifter is machined from 6061 T-6 billet aluminum. It features a relocated pivot point that results in a shorter throw and adjustable stops.
5.5) What size threads are on the factory manual shifter lever?
The stock shifter lever users metric M16x1.5 threads.
5.6) Should I use a gasket with the AAM differential cover?
Using a gasket with the American Axle and Manufacturing will defeat the oil circulation feature of the cover and is not recommended. It's probably possible to cut holes in the GM gasket but that is not recommended either.
5.7) What is the grey sealant used on the AAM differential cover?
SLP uses a sealant is called Three Bond 1216; it is imported by Three Bond of America, Inc. It is a high temperature, non-hardening product that and is not adversely affected by the GM Lubrizol differential additive.
Three Bond does not market this product directly. However it is available from a Suzuki motorcycle or car dealer. They call it Suzuki 1216 (part number 99104-31160).
5.8) What is the proper differential fill?
According to the Camaro owners manual, the Torsen limited slip differential uses 2 quarts of synthetic 75W-90 oil (GM part number 12378261 or equivalent) and 4 ounces of GM Limited-Slip Differential Lubricant Additive (aka Lubrizol, GM part number 1052358).
According to the SLP owners insert, the Auburn uses 2 quarts of non-synthetic 80W-90 oil and 2 ounces of Lubrizol.
In both cases, the Lubrizol friction modifier is only used to reduce noise from the differential. However, leaving it out may affect your warranty.
5.9) What are the transmission ratios?
The ratios for the RPO MN6 Borg Warner T56 six speed manual are as follows:
Gear
1st
2nd
3rd
4th
5th
6th
R
Ratio
2.66:1
1.78:1
1.30:1
1.00:1
0.74:1
0.50:1
2.90:1
The ratios for the RPO MX0 4L60E four speed electronic automatic are as follows:
Gear
1st
2nd
3rd
4th
R
Ratio
3.06:1
1.63:1
1.00:1
0.70:1
2.29:1
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 06-23-2009, 12:49 PM   #4
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
In short to save gas and save us a gas guzzler tax but try this handy dandy feature its been discussed many many times on here.
Search skip shift or CAGS, which i think is computer aided gear selection
jpsuperman81 is offline   Reply With Quote
Old 06-23-2009, 12:50 PM   #5
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
It is the skip shift feature...... saves on gas mileage if you're not driving in a more than normal way. Meaning if you were to accelerate a little longer or faster, you wouldn't have that skip shift coming on. There is a part to install that will prevent it.
stikSS is offline   Reply With Quote
Old 06-23-2009, 12:53 PM   #6
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Originally Posted by jpsuperman81 View Post
In short to save gas and save us a gas guzzler tax but try this handy dandy feature its been discussed many many many many many many many many many many many many many many many many many times on here.
Fixed it for ya
UCF w00t is offline   Reply With Quote
Old 06-23-2009, 12:54 PM   #7
jpsuperman81
Yep I'm back!
Good fix UCF i knew I left something out lol.
Old 06-23-2009, 01:20 PM   #8
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Auto Tranny.
Old 06-23-2009, 01:45 PM   #9
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
I just got my skip shift eliminator. I plan to install it this weekend.
Old 06-23-2009, 02:20 PM   #10
zq8colorado04
zq8colorado04's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Alright so if you use the 1-4 skip shift do you shift to 5th after the engine revs in 4th to 3k?
Or if you have to slow down, do you put it in 3rd or 2nd? or leave it in 4th as if it were in 2nd already?
3000: 03/26/09
3300: 05/08/09
3400: 05/12/09
3800: 05/25/09
4200: 05/28/09
5000: 06/09/09
6000: 06/09/09
VIN# A9111943
2SS/RS Black on Black with LS3 and a 6-speed Manual
15% Window Tint
CAI
StainlessWorks Catback Exhaust
BMR 1.4" lowering springs
zq8colorado04 is offline   Reply With Quote
Old 06-23-2009, 02:27 PM   #11
BigRigMike
BigRigMike's Avatar
Drives: 2010 Ford Fusion
1-4-5-6 the intent is for you to skip 2 and 3. Once you shift if you need to slow down you can use all gears as usual.
BigRigMike is offline   Reply With Quote
Old 06-23-2009, 02:43 PM   #12
3GPa
3GPa's Avatar
Drives: SOLD/2SS/RS Painted Rally Stripes
I've got my Cags, but no car yet.
SLP Performace had free shipping
Gus
3GPa is offline   Reply With Quote
Old 06-23-2009, 03:07 PM   #13
A.J.
A.J.'s Avatar
Drives: 2014 Impala
Don't have my manual handy but I'm quite sure it says 1 quart of synthetic 75W-90 oil and 2.5 ounces of GM Limited-Slip Differential Lubricant Additive. That's exactly what I put in and it started to run out the filler/inspection hole.
Ordered on 10-14-08 - Silver Ice Metallic/Black Leather 2SS/RS, 6 Spd, Sunroof, Polished Wheels. Build date: 04-17-09, VIN 3978, Delivered 04/29/09! Sold on 04-16-2012 :(
ZL1 Ordered on 10-29-11 - Silver Ice Metallic, 6 Spd, Sunroof, Polished Wheels, Exposed Carbon Fiber Insert. Build date: 05/17/12, VIN 1415. Delivered 05/30/12!!!! Sold 05/28/12
A.J. is offline   Reply With Quote
Old 06-23-2009, 03:14 PM   #14
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
Which one?
Embalmer is offline   Reply With Quote
6 Speed shift pattern changed? Crowkillers 5th Gen Camaro SS LS LT General Discussions 43 08-07-2015 12:18 PM
do you speed shift when racing? s.norman 5th Gen Camaro SS LS LT General Discussions 33 03-05-2009 08:36 PM
