HeadlightArmor
Old 04-15-2013, 02:17 PM   #1
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
Running our rear rims as fronts
Hi all, I have a spare rear on the way and now I have become a little bit curious. Is it possible to run the ZL1 rears on the front of the car for 11's all around?
Thanks in advance,
Matt
snickerdoodle is offline   Reply With Quote
Old 04-15-2013, 02:34 PM   #2
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I may be wrong, but I thought someone tried this, and the wheel hit part of the suspension. They discovered this, as I remember, because the rear wheel they had was marked front.
gajagfan is offline   Reply With Quote
Old 04-15-2013, 03:05 PM   #3
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Agreed with above.....I believe it rubs on the front strut.
Old 04-15-2013, 07:52 PM   #4
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
^ yep. Tried it for fun one weekend. It is a no go...
Phdpsy is offline   Reply With Quote
Old 04-15-2013, 08:16 PM   #5
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
The Camaro was designed with a staggered wheel set up in mind. Therefore the offsets are different.
2cnd chance is offline   Reply With Quote
Old 04-16-2013, 11:15 AM   #6
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
...which will it be.... sig or avatar?
tramtwo is offline   Reply With Quote
Old 04-16-2013, 11:25 AM   #7
2cnd chance
Exactly!
Old 04-16-2013, 05:05 PM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Thanks in advance,
Matt
275s is pretty much the max width on any model besides the ZL1. Anything wider and you will have rubbing on the suspension and fender.
Old 04-16-2013, 06:10 PM   #9
Synner
Drives: not stock
Not really, you can get 285 or 295's without rubbing depending on tire brand and wheel choice. Heck the 1le and ZL1 have 285's in the front from the factory.
305's will rub a bit but can be done with perfect offsets. Thats the route I'll be taking, screw the fender liner I want tire.
Old 04-16-2013, 10:34 PM   #10
snickerdoodle
This is false. there are people with 315's. This is the setup I plan on moving to.
Old 04-17-2013, 07:51 AM   #11
toehead93
Drives: 2014 2SS/1LE
Dont those with 315s have coilovers which are much narrower than the stock springs?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 04-17-2013, 05:17 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Not with factory suspension.
The 1LE and the ZL1 has a different suspension setup then the SS which is why they can go wider.
Old 04-17-2013, 05:27 PM   #13
snickerdoodle
Ah I gotcha, didn't notice you had the SS
