sjm autoprod
Old 04-15-2013, 11:56 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Smile NEW EXHAUST
So I got my car tuned and dyno with the TVS 2300 , slp loudmouth 1 with no cats. After 2 weeks of driving like that, I could not bare the noise and rattle anymore. So I installed the slp 2 exhaust. I noticed now that when I had the slp 1 that it would read -20 to -4 when I will be cruising, now with the new exhaust I stay around 0 thru 3 on the boost psi gauge.I am guessing since it has some back pressure now. Am I going to have to get it retuned? or is this normal? Just want to be on the safe side.
lincoln361 is offline   Reply With Quote
Old 04-16-2013, 03:36 AM   #2
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
From what I have read there is no back pressure difference between exhaust systems on this car. Perhaps a sensor malfunction. I'd call your tuner on this one..
What rattle are you talking about??
K32 Camaro is offline   Reply With Quote
Old 04-16-2013, 07:46 AM   #3
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
There is always some back pressure. When running a supercharger if you make intake or exhaust changes i.e. ported throttle body, adding headers or in your case changing axel back muffler sections. Unless its an identical component it will affect airflow and thus affect your fuel/air ratio. I would put it on a wideband A/F guage and log it to be sure but if the boost guage changed. There's a reason it changed. Remember more restriction will show more boost, to a point .
UNRIVALED SS is offline   Reply With Quote
Old 04-16-2013, 09:30 AM   #4
old motorhead
Drives: Maggie blown LS3 vette
If you're showing ANY boost at cruise (unless you're climbing a hill), something is wrong.
old motorhead is offline   Reply With Quote
Old 04-16-2013, 11:05 AM   #5
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
I have the TVS2300 & SLP LM II and my boost gauge reads what yours was reading before you made the switch, which are normal numbers. Your numbers should remain the same from the Loudmouth to the Loudmouth II, I'd call your tuner.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
