Frankenstein Engine Dynamics
Old 06-23-2009, 02:18 PM   #1
Sloppy Joe
Sloppy Joe's Avatar
Drives: 2SS RJT
Radar Detector Hardwiring? - Tapping into 12V Accessory
Has anyone hardwired their radar detector in yet? If so, where were you able to tap into 12v power that is only hot when the key is turn on ? Did you tap into the wiring harness by the BCM, run a wire to the engine fuse block or tap in someplace else?
(Update::Found 12V accessory (switched power) it's the Brown wire in the light green plug going into the BCM above the gas pedal.) Eactly as discribed in the wiring sticky.
Sloppy Joe is offline   Reply With Quote
HALP - need 12v remote wire in trunk. Adam Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 06-17-2009 09:41 PM
Hardwire Radar Detector? mhennick Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-13-2009 10:27 PM
Radar detection systems? DGordon Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 68 04-02-2009 09:05 PM
radar and laser detector and jammers Az Sparky Off-topic Discussions 49 08-27-2007 10:03 PM
