sjm autoprod
Old 04-16-2013, 02:09 AM   #1
hoohah797
Drives: Ford Ranger now, 2SS LS3 ordered!
Hill Assist Sensor
Does anyone know where the sensor for the hill assist is located on a 2013 LS3?
hoohah797 is offline   Reply With Quote
Old 04-16-2013, 06:22 AM   #2
Dupree878
Dupree878's Avatar
Drives: '13 Dusk Edition 2SS/RS M6
It's all part of the StabiliTrac system and ABS
There's not just a sensor.
Dupree878 is offline   Reply With Quote
Old 04-16-2013, 06:26 AM   #3
Dupree878
Dupree878's Avatar
Here are the threads in which I've been involved about HSA:
http://www.camaro5.com/forums/showthread.php?t=256232
http://www.camaro5.com/forums/showth...=277285&page=2
http://www.camaro5.com/forums/showthread.php?t=240676
http://www.camaro5.com/forums/showthread.php?t=218714
Old 04-16-2013, 07:50 AM   #4
SSRS1LE
Drives: 2013 Camaro 2SS/RS/1LE
There is in fact a "pitch sensor" that GM describes in the HSA system used in the Sonic. I'd imagine the same setup is used in the Camaro:
"In a Sonic equipped with hill-hold, a pitch sensor detects the tilt of the body when the car is stopped on a slope and sends a signal to the stability control system."
https://media.gm.com/content/media/c...cHillHold.html
I tried researching where this sensor actually is, but haven't found any answers yet either.
____________________________________
Modifications: HSA Elimination - Cold Air Inductions Intake
Solo Performance Mach Cat Back - Skip-Shift Eliminator
SSRS1LE is offline   Reply With Quote
Old 04-16-2013, 09:41 AM   #5
Dupree878
Dupree878's Avatar
A tech told me the pitch detected through the gyro sensor that decided when StabiliTrac needed to intervene
Old 04-16-2013, 10:39 AM   #6
SSRS1LE
StabiliTrac uses separate yaw and pitch sensors, which are a lot more simple than a gyro sensor. The yaw sensor is part number 13575612.
http://www.saeparts.com/ProductInfo.aspx?id=7931838
The pitch sensor is a separate part that was added to 2012 Sonic and 2013 Camaro. Haven't been able to find the part number or location yet though. If anyone knows where the yaw sensor is located, odds are it would be mounted in that same area.
Old 04-30-2013, 02:47 PM   #7
MPHS_AGM
MPHS_AGM's Avatar
Drives: 2013 Camaro 2SS/RS/1LE AGM
I realize this is a couple of weeks old, but I figured I would interject here...
According to the factory service manuals, the yaw sensor (located under the center console) is a multi-axis sensor that provides data to the traction control system and the ABS. This is not verbatim, but a summary. This information is listed under the ABS with F55 option (Magnetic Ride Control i.e. ZL1) and also states that the HSA is disabled when the stability control is turned off. So far no one has been able to confirm this action.
Current:
2013 AGM 2SS/RS/1LE-NPP
Past:
2002 Z28 Navy Blue A4 [traded]
1996 Camaro V6 Black [traded]
MPHS_AGM is offline   Reply With Quote
Old 04-30-2013, 02:59 PM   #8
dwinva
dwinva's Avatar
Drives: 13 2SS/RSvert,CRT,dual-mode exhaust
Crappy weather around me to day so I didn't drive my Camaro. Our house is on top of a hill so I can easily see if this works or not when I get home today and I'll report back what I find.
No luck with any combination (TC off, Stabilitrak off, holding button down for 8 seconds and turning everything off, holding the clutch in while trying these combinations as well as putting in neutral and foot off of the clutch while trying them again). I thought I had success at first with T/C off, but it just turned out to be my hill assist timing out after 2 seconds.
Sigh...oh well. It was worth trying.
dwinva is offline   Reply With Quote
Old 04-30-2013, 06:25 PM   #9
Lickwid Apex
OD
Drives: '16 HB 2SS A8
Send a message via Yahoo to Lickwid Apex
Thanks guys for digging and digging. The closer you get the happier some manual drivers are going to be. I would love for this to be defeatable or at the least driver selectable.
Lickwid Apex is offline   Reply With Quote
Old 05-01-2013, 06:56 PM   #10
Dupree878
Dupree878's Avatar
Still comes on when stability control is off. It may be less sensitive
