Caryle Racing
Old 04-17-2013, 09:23 AM   #1
AnthonySS10
Drives: Black 2010 SS
Need Advise after cam install
Installed cam/valve springs/ push rods (Texas Speed and Performance package) went good, car started right up, good oil pressure. Drove car 140 miles to get my dyno tune _after a few adjustments on the tune car turns over but wont start. Tried factory tune and same thing no start- shop and I believe timing off, but checked all fuzes -good, good fuel pressure, has spark, no displays have came up for anti theft. Brought car to dealer for possible ecu reflash, they say ecu is good no problems with reading-no codes-advised maybe jumped timing need to remove front cover for inspection. wrecked car back to my place, removed valve cover all looks good, pulled off front cover and timing marks lined up correct(cam at 6 and crank at 12 #1 tdc). Im stumped now on what to look into next any help would be nice.
AnthonySS10 is offline   Reply With Quote
Old 04-17-2013, 03:00 PM   #2
Ryan K
Drives: 1998 Camaro B4C
Datalog while cranking the car make sure it is reading Cam and Crank position sensors. Also, check injector PW to see that it is trying to fire the injectors.
98 Camaro B4C
Turbocharged By Turbo Technology Inc.
9.0 @ 154 mph
Ryan K is offline   Reply With Quote
Old 04-17-2013, 03:19 PM   #3
Ryan K
What program was the tuner using to reprogram the ecu? It is a possibility that he bricked the ECU. I have seen bricked ECUs "seam" to function but they were not actually firing the injectors...
98 Camaro B4C
9.0 @ 154 mph
Old 04-17-2013, 04:45 PM   #4
AnthonySS10
He was using EFI live. I will try those once I get off work. Thanks Ryan
Old 04-17-2013, 09:14 PM   #5
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
how many times did you try to turn it over? which cam timing gear did you use? i used the incorrect timing gear the first time around and had starting issues...sometimes it would start up the first time. but generally by default on the 3rd try. just something to think about.
hapisok is offline   Reply With Quote
Old 04-18-2013, 01:01 AM   #6
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
Was the crank relearn done after cam install? Just a thought.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 04-18-2013, 09:17 AM   #7
AnthonySS10
I have not done the relearn procedure, about to look that up....During the different items that we checked tried to start a good 50 times and always sounds like timing is off
Old 04-19-2013, 10:26 AM   #8
AnthonySS10
Found #1 intake lifter has problem. Off comes the head for inspection......
Old 04-19-2013, 11:08 AM   #9
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
It's likely collapsed and not pumping back up. On another thread CFD had the same thing happen, but in his case, the roller came off of the lifter.
Bye bye, Bumblebee!
Old 04-19-2013, 04:48 PM   #10
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Cant see one lifter preventing the car from starting. Very strange that it started and ran until the tune was touched. Keep us posted. I am curious what the issue could be.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 04-19-2013, 08:36 PM   #11
Ryan K
My bet is bricked pcm.
98 Camaro B4C
9.0 @ 154 mph
Old 04-23-2013, 11:45 AM   #12
Ryan K
Any update?
98 Camaro B4C
9.0 @ 154 mph
Old 04-23-2013, 04:52 PM   #13
AnthonySS10
Removed timing cover and found dowel pin on cam broke and allowed cam to get of time, which made pistons hit valves since not operating properly. So now heads get fixed and have to install new cam(3 bolt) and fix pistons or replace and new timing chain set. Lesson learned on cam never go with single bolt cam........
Old 04-24-2013, 03:46 PM   #14
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
