Jason 98 TA
Old 04-17-2013, 07:02 PM   #29
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
Originally Posted by 954camaro View Post
Usually when I am at a red light I usually shift my automatic into neutral while waiting at a red light. Should I stop doing this? The only reason why I am even putting it into neutral at a red light is because I thought it decreases my wear and tear on my brakes.
Thanks guys
When you're stopped, the wheels aren't doing a lot of turning so it's difficult for me to imagine what wear you are avoiding
Brakes pads are wear and tear items. The fact that you stopped does much more to wear them out than the fact that you have remained stopped.
ChrisBlair is offline   Reply With Quote
Old 04-17-2013, 07:05 PM   #30
C586
Drives: 2011 Camaro LS
Why would you even think of shifting into neutral at a light?? It doesn't even make sense why you would do that?? Any time you move something it wears. So yea. Just leave it in drive. That's why you have a torque converter.
C586 is offline   Reply With Quote
Old 04-17-2013, 07:09 PM   #31
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
IMO, shifting into neutral (with an automatic) while driving should only be used during the winter season when you need to come to a stop at either a stop sign (light) or for a turn. It helps slow the vehicle down and you don't have to apply the brakes as much reducing the chance of skidding. It works really well, especially when the roads haven't been plowed.
Brakes are made to stop your vehicle, they don't wear that fast, I'd be more concerned about causing any potential wear on the transmission. A lot more expensive to replace.
SPARTAN sui is offline   Reply With Quote
Old 04-17-2013, 08:03 PM   #32
C586
Contradict much??
Slipping the trans in neutral is never a good idea. Ever. Use your brakes. That's what they are there for. If you can't slow down with your brakes you need to learn to drive or get tires meant for the situation or something. I get alot of bad snow and I am always driving on unplowed roads.
Old 04-17-2013, 08:21 PM   #33
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
Shifting into neutral while driving will SPEED UP your car. Putting the car into low gear will slow down the car mechanically and would help in scenario you describe, but is still unnessasary .
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 04-17-2013, 08:27 PM   #34
C586
Unless your going downhill that's impossible. If putting it in neutral will speed your car up ill start driving around in neutral. The car will get better mpg idling everywhere. Ya know what.. Ill even shut the engine off since I don't need it anymore. Lol.
How could a car speed up if there are no forces making it do so??
Old 04-17-2013, 08:29 PM   #35
GYac
GYac's Avatar
Drives: 2010 2SS
Originally Posted by Trentin24 View Post
What if you shift it into neutral after you stop. On a flat surface so it doesn't roll? I've done this after working out or games when my legs are tired. I have also shifted into neutral going down hills. Is that bad?
Let me a bit more precise about my previous post. With an automatic I personally wouldn’t shift it into neutral when I stop at a light, if I had too I’d put it in park so I wouldn’t role. Going down hill I would not do either, this is not a manual, re-engaging your automatic at a higer RPM if you hit the gas early or something could do serious damage. I am NOT a mechanic nor do I claim to be one.
With a manual car I use neutral a lot, in my camaro I will coast down hills and around corners. They are two different trannys. I have my own driving style, my wife asks me all the time why I shift into neutral a lot, i just tell her each person has their own way of driving a standard car, this happens to be mine, I also shift from 1, 2, 4, 6 sometimes when just cursing around town.
to each their own i will never tell anyone how to drive their car, however i just don't understand the point of shift an automatic into N at all, i cannot remember the last time i used that gear in an automatic car, but thats me. to each their own!
GYac is offline   Reply With Quote
Old 04-17-2013, 08:30 PM   #36
GYac
GYac's Avatar
Drives: 2010 2SS
I'm not tracking please explain?
Old 04-17-2013, 08:36 PM   #37
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Just get up to top speed as quickly as possible...go to nuetral right away and start coasting for as long as you can...It'll save your clutch and wear and tear on the auto-trans...(If you turn off engine at this point you will really save gas, but lose power-steering, so be careful)....Re-start car as needed...lol...
90503 is offline   Reply With Quote
Old 04-17-2013, 08:43 PM   #38
Cheveey57
Cheveey57's Avatar
If you are slowing to a stop and shift into neutral the car will actually roll faster out of gear.
Old 04-17-2013, 08:49 PM   #39
unkbd
unkbd's Avatar
Drives: 2010 IBM 2SS/RS
Thanks guys
If I read this right you are already stopped at the red light. No motion with the brakes applied equals no wear and tear on your brakes. Cut it out. Just my two cents
unkbd is offline   Reply With Quote
Old 04-17-2013, 09:02 PM   #40
SPARTAN sui
PC Technician
Originally Posted by C586 View Post
Contradict much??
Hmm, I stand corrected. I wonder why this is everywhere on the internet? I heard this first from my parents.
Old 04-17-2013, 09:30 PM   #41
C586
In their time maybe but with a modern car with modern brakes and tires and traction control its not true anymore. You paid for all that fancy crap so use it or at least give it a chance. And coasting in neutral will result in lower mpg. When the car is engine braking the injectors don't get pulsed so no fuel is used. When its idling its using fuel.
Old 04-17-2013, 09:39 PM   #42
SPARTAN sui
PC Technician
That's good to know, thanks for the information.
I've only done it a few times during the season, must have been a false sense of slowing the vehicle down. I do have proper tires at least, I'd be stranded with my P-Zero AS tires.
