Emblempros
Old 06-25-2009, 11:41 PM   #15
Foster26
Drives: 2SS/RS IOM 6SP CGRS #9761
Originally Posted by franknbeans View Post
Dude, the car comes with Mobil 1 in it.
Are you 100% certain the car comes with Mobil 1 [I]synthetic?[I] I would be willing to bet when that motor is first run, it does not have synthetic. If you know anything about new engines, rings have to wear and seal, valves have to seat. If you use synthetic during break-in, it us unlikely these things will happen properly. I have been working with race engines long enough to know this and it would surprise me if they are using synthetic oil at start up. Recommending you use it does not mean it has it in now. I don't know.
Foster26 is offline   Reply With Quote
Old 06-25-2009, 11:45 PM   #16
faninc
Drives: 2010 Camaro RS in SIM
My C6 Vette came with Mobil 1 and the oil cap actually says Mobil 1 on it. I think that 400HP engine would be considered "race" engine.
best
J
faninc is offline   Reply With Quote
Old 06-25-2009, 11:53 PM   #17
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Yes, it's been stated a billion and one (make that a billion and two now) times that it does, in fact, ship with Mobile 1 from the factory.
UCF w00t is offline   Reply With Quote
Old 06-26-2009, 02:03 AM   #18
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
I'd bet my car on it, this car 100% comes with Mobil 1, as does the C6, as did the C5. And even the 4thgen LS1 cars did....
2010 Chevrolet Camaro SS - was daily driver, now toy
2014 Mercedes Benz E350 4matic Sport - Daily Driver
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1995 Volkswagen Golf Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 06-29-2009, 08:40 AM   #19
Foster26
Mobil makes conventional oil too. No one is disputing that synthetic oil is not the best option for BRAND NEW engines.
Old 06-29-2009, 08:45 AM   #20
Foster26
I'm not disputing the car comes with Mobil 1. I'm saying it might not be synthetic if it is the original oil put in the motor when they started it the first time. My speculation is that the oil in it now is Mobil 1 but NOT synthetic (if it's the original oil), or they have changed it before shipping. I wish someone with real knowledge would confirm or deny my speculation.
Old 06-29-2009, 08:51 AM   #21
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
It is mobile 1 synthetic that is put in..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 06-29-2009, 09:54 AM   #22
CTS
Drives: 2015 Sierra Denali 6.2L CC 4WD
rings don't seal and valves don't seat very well with synthetic oils. Motors should be broken in with conventional oil as a little wear is needed for these things to happen. I plan on changing mine to Amsoil after 3K miles.
Myth, total myth.
My 2009 CTS came wit synthetic oil and has over 3,000 miles on he oem and has not used a drop of oil. My 2005 CTS came with synthetic oil and it was the same, never used oil.
They do not change the oil at the factory, what they put it stays there till the customer changes it. The engine is not run until it is fired up near the end of the assembly line. Fyi-You car get a lot of use before you get it. It may have less than 10 miles on but before it left the plant is had to undergo validation where its run on a dyno up to 75pmh for a period of time to pass emissions and to certify all components work. I seen them run the Corvette's thru this validation and its not babied. It rolls on the ramps and they slam to pedal to floor and bring it up to 75mph for a period of time. When everything pass's the test, a green light comes on and the doors to the special room open and they drive either to repair or to the water test.
All these GM cars/truck come with synthetic oil
# All Cadillac Vehicles
# Chevrolet Corvette C6 and Z06
# Chevrolet TrailBlazer SS
# Cobalt SS S/C Coupe
# Pontiac Solstice GXP
# Saturn Ion Red Line and Saturn Sky Red Line
One of the myths surrounding synthetic oils is that new engines require a break-in period with conventional oil. The fact is, current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design the high-performance cars listed above, Mobil 1 can be used starting the day you drive the car off the showroom floor.
Here is a reply from someone I know in GM Powertrain at St Catharines (Canadian engine plant).
Re: Any Camaro engines coming with Synthetic oil?
« Reply on: April 30, 2009, 12:38:56 PM »
Yep, Mobil 1 in Camaros and Vettes, some trucks as well.
Mike
2015 GMC Sierra Denali 6.2L 1500 CC Standard Box 4x4
Synthoil Supply
CTS is offline   Reply With Quote
Old 06-29-2009, 10:59 AM   #23
Rogue Leader
Mobil 1 IS synthetic only. Regular Mobil oil is just called Mobil. Any Mobil with a 1 on it is Synthetic.
Old 06-29-2009, 12:36 PM   #24
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
Modern day engine components and technology don't require conventional oil for break-ins. It is just the advancement of technology these days.
As for the original poster:
I changed my oil and filter at 489 miles. Put Mobil 1 and K&N filter on it.
I then changed it again at 1601 miles. Once again, Mobil 1 and K&N filter.
They say you don't need to change until 1500 miles, but I rather be safe and give it a nice healthy supply of clean oil during break-in.
As for Royal Purple or Mobil 1 - this is a disputed argument between many. They are both FANTASTIC oils! I am a Mobil 1 man, I only ever put Mobil 1 in for anything - including the rear-end fluid I changed. However, my neighbor is a Royal Purple fan - only puts Royal Purple in.
What are the advantages of either? Well, other than price for Mobil 1 compared to Royal Purple, not much. They are both synthetic and both very good oils. Just some people swear by one or the other.
If you want to go with Royal, go ahead - 1500 miles put it in. If you want to stick with what was in the engine to begin with, put Mobil 1. It is just up to you as to which you prefer, but both will be fine.
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
RickyTheStorm is offline   Reply With Quote
Old 06-29-2009, 07:02 PM   #25
FirstCamaro2010
Drives: none
I researched the part numbers of what the V6 comes with and matched it with mobile's website of what vehicles come with what oil and from what i found the V6 comes filled with Mobile Clean 5000 a conventional oil and the v8 is Fully Synthetic Mobile One
FirstCamaro2010 is offline   Reply With Quote
Old 07-01-2009, 08:46 PM   #26
faninc
well looks like the Mobil 1 debate goes on for V6?
Old 07-01-2009, 11:02 PM   #27
Vash
Drives: 00 Blazer
Yea I noticed that too the other day.
Just use Royal Purple 5-30. It's got the certifications needed to keep the warranty golden.
Old 07-01-2009, 11:10 PM   #28
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
How about:
1) Someone with a V-6 pop their hood and verify that the "Mobil 1" sticker is/is not there.
2) Send a sample of your "used" motor oil to Blackstone Labs after you have supposedly "used its life up" at 3000 miles. You'll be surprised at what they say and how they verify and back up what they are showing you. (You are wasting your money changing your oil at 3K). Qualifier...I'm not talking about the first 1500 miles here. I have my own strong opinions about that. I mean after the initial 1500 miles.
3) Learn the difference between type 3 and type 4 synthetic. Amaze your friends.
4) Don't believe a word I say. I'm full of crap.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
Synthetic? shroomjohn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 09-18-2008 02:31 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
