Gen5DIY
Old 06-23-2009, 07:30 PM   #1
DEW
Drives: Hoopdee
V6 Oil Filter Cartridge
Want to stock up on some oil filters for my v6 Camaro before it arrives. Anyone got any part #s (Wix, K&N, ect.) Not sure what brand I want to use yet. Any recomendations?
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 06-23-2009, 08:13 PM   #2
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
K&N's HP-7003
Kahdir is offline   Reply With Quote
Old 06-23-2009, 09:56 PM   #3
rays
V6 - It just isn't normal
rays's Avatar
Drives: 2010 2LT M6, F250 7.3L Diesel
Not many options for the V6
Purolator L25274
Fram CH8765
And the K&N
I'm sure Napa has one but I cant find the part.
I'm thinking the Purolator or K&N
2LT RS M6 RJT Black leather
4/29/2009 Ordered
6/24 6000 Delivered
rays is offline   Reply With Quote
Old 06-24-2009, 12:20 AM   #4
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
AC Delco oil filter for the 3.6L : Part# PF459G / GM# 12593333 or **PF2129 , ** most common part # to find at AC Delco Dealers and local Auto Parts Stores ..
I buy my filters ( PF2129 ) from Bumper to Bumper Auto Parts for $5.10 ea. (tax included).
Napa Auto Parts :
Napa Gold oil filter #7090 / Wix oil filter #57090 @ 7.69 ea (tax included) .
Or go online to : www.fleetfilters.com for Napa Gold / Wix oil filters @ $4.48 plus tax and shipping ..
fee5fofum is offline   Reply With Quote
Old 06-24-2009, 07:47 AM   #5
DEW
Drives: Hoopdee
Thanks
BUILD - 6/12/2009
Old 06-24-2009, 09:24 AM   #6
bob2the2nd
Drives: CGM 2LT RS
im trying to take advantage of the mobile 1 deal anyone know which oil filter to use from mobile 1?
2LT CGM auto/sunroof/RS
1100: 11-29-08
6000: 6-29-09
cracked windshield: 7-1-09
1000 miles 7-4-09
windshield replaced: 7-9-09
2000 miles 7-10-09 (yep 2000 miles in 11 days)
3000 miles 7-16-09
4000 miles 7-30-09
bob2the2nd is offline   Reply With Quote
Old 06-24-2009, 10:44 AM   #7
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
I've used Wix for years in my 3.6 CTS.
#57090
HaveBlue is offline   Reply With Quote
Old 06-24-2009, 01:50 PM   #8
dagolfguy
dagolfguy's Avatar
Drives: 2010 Camaro 2LT RS
Is the oil change procedure with these cart filters as simple as it is with single piece the disposable type?
dagolfguy is offline   Reply With Quote
Old 06-24-2009, 09:52 PM   #9
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
Yep, when you take the engine cover off there is a round aluminum cylinder next to the driver side cam cover. Unscrew the top. Pull the cartridge out and drop the new one in.
Still have to get under the car to drain the pan.
Also DO NOT go by the oil life monitor. As some CTS owners have found out the hard way it's too long. My service tech told me "you should change your oil probably 3 times before the monitor tells you to." He told me they've had cars come on on the hook that wouldn't hardly turn over. Changed the oil (or goo) and problem solved. Mine gets fresh oil every 3000.
Old 06-25-2009, 04:43 AM   #10
kutch720
kutch720's Avatar
Drives: Camaro 1LT RS
While I agree with not relying on the oil life monitor. The owners of those cars that came in on the hook obviously did not change there oil in a very long time. Oil is alot better now than it was back in the day. Good oil does not break down until around 5000 miles. I will still change it out every 3000, but just saying. Also we should really be monitoring our oil by hours instead on mileage anyway.
kutch720 is offline   Reply With Quote
Old 06-25-2009, 10:50 AM   #11
dagolfguy
dagolfguy's Avatar
Speaking of oil life, the amount of oil in these new aluminum block engines should extend the life simply because more oil will result in less breakdown. The oil should not be particularly contaminated after only 3,000 miles unless there are other problems. Generally speaking, it's the additive package that breaks down not the molicules of the oil anyway. So more volume of oil should equal longer life just like on the bid diesels.
Thoughts on that?
Old 06-25-2009, 11:03 AM   #12
bhut
bhut's Avatar
I tend to go with the oil life monitor. Given the quality of the oil today, machining tolerances, and the expectation of getting at least 150k miles out of a car, companies would be screwing themselves otherwise. I run Mobil 1 and either Wix/PureOne/Bosch filters (availability or vehicle). If I was running cheap oil and filters from the local express lube, I might be more concerned.
bhut is offline   Reply With Quote
Old 06-25-2009, 01:52 PM   #13
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
Just passing on what I've learned in 5 years of owning a 3.6VVT.
If you know a friendly GM Tech (especially at a Cadillac dealership) ask them. They will tell you that the oil life monitor is one thing. Marketing.
I know my oil (regardsless of the brand) goes in clear and comes out black at 3500 miles. It's contaminants not viscosity breakdown. What gas you use (and the state you life in, we have no gas quaility testing in OR and the gas is crap) will have more of a factor than oil brand. I've run Mobil1, Redline, Valviline Syn. The viscosity is excellant I'm sure I could (and did in my first 3.6) run it longer, but it still gets dirty.
Old 10-07-2009, 10:37 AM   #14
TitanTerry
TitanTerry's Avatar
Drives: 2010 Camaro, 2LT, RS, ABM
It wasn't a Camaro engine. It was a Nissan 4 cylinder. I used Castrol GTX 10 w 30 and changed oil and filter every 6K miles and got over 350K on the engine with no smoking when I sold it.
I was thinking of going every 4K miles with this engine and sticking with Castrol GTX. Is synthetic oil required for this engine?
Thanks
~ It's not a car...
~ IT'S A CAMARO!
Ordered: 07/02/09
HOME - 9/25/09
TitanTerry is offline   Reply With Quote
What oil and filter will you be using ? larietrope Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 65 07-21-2009 10:22 AM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
