BeckyD @ James Martin Chevy
Old 04-17-2013, 07:40 PM   #1
1LeSS
1LeSS's Avatar
Drives: 2013 2SS/RS VR 1LE
Alignment specs
Does the 1LE have different alignment specs than a SS?
1LeSS is offline   Reply With Quote
Old 04-17-2013, 10:17 PM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Good question as it has more adjusts available than the SS....Subscribed...
Pete Justice???
Old 04-17-2013, 10:44 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I was wondering this myself. I had a feeling at least the first alignment needed to go to the dealer until the local monkeys at the GoodYear shop got some info... I still don't know if I trust them.
Firefighter is offline   Reply With Quote
Old 04-17-2013, 11:13 PM   #4
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Pete's table with alignment specs for the gen 5 doesn't note anything different for the 1LE vs SS. He also did nit note anything in the PMs we exchanged about it. Regardless of what it is supposed to be, it can be quite different. I had mine checked (and adjusted at 400 miles). "Stock front driver camber was -0.7 on driver side.....-1.7 on passenger side. Rear toe was also way off. It is dead on now and handles great. Don't always assume it is at stock specs just because it is new. Get it checked even it is not pulling or exhibiting other issues..I Always get new cars checked and aligned. I would have eaten up a couple tires really easily if I had just driven it..
ZL1 is different though.
Just my $.02
Phdpsy is offline   Reply With Quote
Old 04-18-2013, 12:36 AM   #5
1LeSS
1LeSS's Avatar
Just my $.02
Im with you on this one. Lost a set of tires to the thought that the manufacturer had it right from the factory and I don't want it to happen on this car. 500 more k m s and then I'll get it checked.
Did you take it back to the dealer or go elsewhere to have it checked?
Old 04-18-2013, 12:44 AM   #6
Ryne @ CMS
Ryne @ CMS's Avatar
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra
Same oem specs..
Ryne @ CMS is offline   Reply With Quote
Old 04-19-2013, 10:00 PM   #7
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
I have a shop that I use regularly for anything non warranty. If I knew it was that far off the dealer would have likely done it for free. However, if I can avoid the dealer I do (due to a history of carelessness leading to damage)
Old 07-19-2013, 01:30 AM   #8
meSSohappy
meSSohappy's Avatar
Drives: Waiting for 2018 ZL1 A10
Just had a maintenance alignment done at the dealer on my 11 ss. After 25000 kms everything is awesome.
1st - 2011 2ssrs IOM vert 6spd
2nd - 2015 ZL1 white vert auto
next- 2018 ZL1 hyper blue coupe A10
meSSohappy is offline   Reply With Quote
