Emblempros
Old 04-19-2013, 10:16 AM   #15
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Originally Posted by RBL View Post
Read the Lobe Separation Angle and Overlap Changes part.
I guess my real question should have been, is it bad? And does the car tend to stall?
FSP tuned: 377/389
Old 04-19-2013, 10:34 AM   #16
SC2150
Excellent Chase! A very much misunderstood component, and far to many are NOT matched to the build or the goals of the customer. The 2 biggest subjects I see misinformation on are:
1. NA cam that is also best for FI. No such cam grind exist's.....all will run, but the type FI requires the proper profile to optimize power, and:
2. "I want a lopey/lumpy idle" This we battled for ages with carburated big cam builds.....this is why we have to idle the drag engines at 1000-1200 RPM to get a signal to the carb. This may sound cool, but it is not the most efficient or optimized for power...expecially off idle. Comp introduced their "Thumper" line due to demand for the sound, not optimal performance.
Old 04-19-2013, 10:45 AM   #17
nyrfan
Let's go Rangers!
nyrfan's Avatar
I am very confused by this whole cam thing. So can one be done that give you a nice sound, but does not sound like it is ready to stall? Is there a happy medium?
Again sorry if these are dumb questions, but I am really confused by this.
FSP tuned: 377/389
Old 04-19-2013, 12:11 PM   #18
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
Very informative! Didn't know much about cams till I read this!
Tyler360 is offline   Reply With Quote
Old 04-19-2013, 02:14 PM   #19
Stitch
Stitch's Avatar
Drives: SS, CTS & SRT-4
Very clearly explained.
Thanks Chase!
Stitch is offline   Reply With Quote
Old 05-29-2013, 10:04 PM   #20
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I am glad that you guys are finding this thread helpful.
You can buy an "off the shelf" cam or you can custom spec a cam to accomplish any goal you like. Be it performance, sound, or some combination of the two.
Old 06-07-2013, 04:28 AM   #21
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
I found these numbers to be a happy medium- (LS3)
227/239 .613 .623 LSA 114
Sounds great/makes good power
Bonemaro is offline   Reply With Quote
Old 06-07-2013, 09:35 AM   #22
DrkPhx
DrkPhx's Avatar
The more you read about cams, the more you can get confused; but you have to look at it from a valve timing event perspective, then it becomes easier to decipher and digest all of the information out their. While all aspects of cam design play into cam performance the two key events are intake valve closing point (most important) and exhaust valve opening. But don't take my word for it; read on.
Comp Cams has some good articles on camshafts.
http://www.compcams.com/Pages/413/ca...ion-angle.aspx
http://www.compcams.com/Pages/416/va...-tutorial.aspx
Other artcles:
http://www.popularhotrodding.com/tec...s/viewall.html
http://www.chevyhiperformance.com/te...engine_basics/
Old 06-07-2013, 10:56 AM   #23
CGT
Drives: 2011 SSm6
Other artcles:
Yes, the IVC seems to be the dominant valve event, usually followed by EVO. At least in the testing I've done.
CGT is offline   Reply With Quote
Old 06-28-2013, 05:10 PM   #24
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
So if I got this right, I gotta get all the supporting mods first and with that info I can spec out what cam would be right for my car correct?
MikeMoach is offline   Reply With Quote
Old 06-28-2013, 06:12 PM   #25
Apex Motorsports
To maximize your results, yes.
Old 06-28-2013, 06:44 PM   #26
MikeMoach
MikeMoach's Avatar
Ok but I feel lost, doesn't the size of the lifters depend on the size of the cam?
Old 06-28-2013, 08:15 PM   #27
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
I think Chase should start one of those Sunday morning car shows. Nice to be able to learn something instead of watching a half hour of product plugs.
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 06-28-2013, 11:05 PM   #28
CAP'N B
Cajun Mariner
CAP'N B's Avatar
Drives: 10 Camaro SS/RS 15 Camaro Z/82 AGM
Send a message via Yahoo to CAP'N B
No, the lifter size is determined by the hole in the block that they fit in.
The pushrod length changes sometimes, depending on the cup where the bottom of the pushrod sits in the lifter is. I think a LS7 lifter is taller.
The rocker arm ratio can change the dynamic of the valve events. A 1.8:1 rocker ratio will increase lift and duration.
The engine seems to want to stall at times because the valves are open at the same time, bleeding off compression, or cylinder pressure. At higher RPM this happens too fast to make a big difference. So the engine runs smooth.
Some cams have a few degrees of advance built into them this lowers where the Power will be made in RPM's.this is called the power band.
Now lets confuse them some more. On the automatic cars with the L99 engine we have what is called Variable Valve Timing cams, this automatically advances and retards the cam. It will have both , low end power and upper end power.
'10 Camaro 2SS/RS Red Jewel L99/A6
'15Camaro Z/28 Ashen Gray
CAP'N B is offline   Reply With Quote
apex motorsports, cam, camaro cam specs
