Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 04-19-2013, 10:38 AM   #1
MPHS_AGM
MPHS_AGM's Avatar
Drives: 2013 Camaro 2SS/RS/1LE AGM
Ramps for 1LE?
I have a set of Rhino ramps that I used for my 2002 Z28 and they do not clear the front splitter on the 1LE. What ramps are you guys using with your 1LE?
Current:
2013 AGM 2SS/RS/1LE-NPP
Past:
2002 Z28 Navy Blue A4 [traded]
1996 Camaro V6 Black [traded]
MPHS_AGM is offline   Reply With Quote
Old 04-19-2013, 11:07 AM   #2
newb
newb's Avatar
Drives: 2013 1LE
Try placing a short length of 2x4 on the ground in front of the ramp. That should give you enough clearance to not need new ramps. I used a set of cheap ramps from the auto parts store and the driveway had just the right slope to clear the splitter.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 04-19-2013, 11:17 AM   #3
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Is a floor jack not a better option? I ask because it has been what I have used on all my f-bodies, and await the deliver of our new 1LE.
gajagfan is offline   Reply With Quote
Old 04-19-2013, 11:42 AM   #4
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
By far one of best purchases I made to work on a lowered vehicle was a set of race ramps. I also have a set to assist in loading lowered cars onto a trailer.....Super light weight. Not cheap, but they work
http://www.raceramps.com/
-Matt
Old 04-19-2013, 12:14 PM   #5
SoCal Swagger
SoCal Swagger's Avatar
Drives: RS
i had the same problem with my 2lt/ZL1 front end.
made a DIY ram using 3 2x10x10 search for the instructions but its rather simple first piece was 8 inches long then 6 inches long then 4 and 2. nail or screw
now i drive my car on then if i need to i jack it up from there
SoCal Swagger is offline   Reply With Quote
Old 04-19-2013, 12:19 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
-Matt
This. Rhino Ramps don't offer enough clearance if you're lowered.
Click to view my build thread
Old 04-19-2013, 01:37 PM   #7
MPHS_AGM
MPHS_AGM's Avatar
I don't like working under the car when it is on jack stands. Just my preference I guess. If I won't be under the car then a floor jack should be okay. I should probably check that for clearance too...
Current:
Past:
Old 04-19-2013, 01:49 PM   #8
MPHS_AGM
MPHS_AGM's Avatar
-Matt
Pricey! You weren't joking! I will put these on my Christmas list and hope for the best!
Current:
Past:
Old 04-19-2013, 04:15 PM   #9
Dropspeed
Dropspeed's Avatar
Yes, but well worth it anytime you have to get under te car. Save so much time over driving onto a board or getting out the jack just to get it on or off conventional Rhino style ramps (which I have also)
I was reluctant because of cost, but have not regretted it at all.
Old 04-19-2013, 05:49 PM   #10
Mojave
San Diego Head Tuners
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
-Matt
Yep, I have a set and they rule
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Member of San Diego Head Tuners
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
Mojave is offline   Reply With Quote
Old 04-19-2013, 08:45 PM   #11
james347
Drives: 2006 Crownline
Race ramps do give some. The tires will leave imprints on the ramps, so don't freak out when that happens.
james347 is offline   Reply With Quote
Old 05-08-2013, 06:55 PM   #12
Buckeye
Buckeye
Drives: 2013 2SS RS 1LE
I use the 2 piece 67" Race Ramps for my 1LE. They work perfectly with the lower front end and the splitter.
Buckeye is offline   Reply With Quote
Old 05-08-2013, 07:25 PM   #13
880
880's Avatar
Drives: 2011 Z06, 2004 Cobra, 1991 MR2Turbo
Make your own ramps
880 is offline   Reply With Quote
