| Mechanical Maintenance: Break-in / Oil & Fluids / Servicing Discussions on mechanical maintenance and servicing of your Camaro |
Thread Tools |
![]() Drives: 1995 3.8L Camaro Join Date: Mar 2008
V6 Oil Burn
I remember a while back we were talking about the CTS DI 3.6 and how it burned oil a little. Just wondering if anyone with the V6 has noticed this at all or if it is something that they appear to have fixed already.
Hey, you want to lay the fate of the world on the kid's Camaro? That's cool. I bought a car, turned out to be an alien robot. Who knew? |
Just Lovin' My Camaro!
Drives: CGM 2LT/RS/AUTO Join Date: Apr 2009
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT 50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!? ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!! GOT MY CAR!!!! AND I LOVE IT!!!! |
Resident Gearhead
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
oil burn
I too am interested. Anyone with the V6 using oil in theirs? I'd say a quart in 3k is normal?
Anyone?
Institutionally Insane
During the break in process, it is normal for any engine to burn oil.
I could elaborate, but the process is completely normal/harmless. Expect to see this up to 3-5000 miles.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what? Ordered 2/5/09 1100 2/5/09 2000 4/9/09 2500 4/15/09 3000 4/15/09 3100 4/19/09 3300 5/01/09 3400 5/08/09 3800 5/20/09 VIN 10620 4200 5/22/09 Delivered 5/28/09 |
I understand that it is normal, the question was based on the fact that the 3.6 in the CTS was still burning oil at 15k. It isn't something that is gonna stop me from buying the car, just a question as to if the issue has been solved.
#6 |
Bump...
I am seeing a lot of black soot in the exhaust tips. Is this from burning oil or normal? Will it stop?
#7 | |
That's from running rich at times. My mom's 2005 Acura RL did that too...Honda insisted that it's normal for that car, and GM will probably do the same for the Camaro.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios 2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong) 1980 Buick Lesabre family heirloom with 36,000 miles 2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease Quote:
#8 |
![]() Drives: 2010 Camaro 2SS RS M6 CGM A9125214 Join Date: Jun 2009
My 08 CTS with the 3.6 DI did burn oil, it was about 1/2 a quart between oil changes every 6k miles. The quicklube tech pointed it out when I got my first oil change after that I checked it every month just to be sure i wasnt running her dry. I never had any mechanical problems with the car, it just used a bit of oil.
#9 |
Good to know. Thanks. I'll just keep an eye on it and keep the tips cleaned up.
#10 |
![]() Drives: 2010 Chevy Camaro LT1 RS Join Date: Jul 2009
I just hit 10K miles on my v6 camaro. It has 30% oil life left. I went to check the oil and the dip stick was bone dry. I had checked it when the oil change was first done, and it was full. So mine burns A LOT. It's going in to the dealer today.
#11 |
![]() Drives: Hoopdee Join Date: May 2009
You need to be looking at the white portion of your spark plugs, not the exhaust tips. On a proper running engine, the plugs should look like they just came out of the box or very slight tan color.
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS BUILD - 6/12/2009![]() Airaid V2, Flowmaster AT |
#12 |
![]() Drives: 2010 Camaro 2LT ABM auto Join Date: May 2009
2200 miles and is still full. I check it frequently and expect to change it soon.
#13 |
To All Veterans
Drives: 2010 2LT RS Inferno Orange Join Date: Sep 2009
Ok... so if a motor is burning any oil at all wouldn't that indicate piston ring blow by or some type of engine leakage whether internal or external?? I'm not an engineer but to me there are only two ways for an engine to loose oil 1, leakage through faulty gasket seating or 2, faulty engine break in procedures causing piston rings not to seat properly to the cylinder wall....thereby causing engine blow by when internal pressures exceed the rings capability to hold that pressure.
#14 |
Resident Gearhead
2,155 miles and still full, just got the first oil change.
#15 |
![]() Drives: 1969 Chevelle, 2010 1LT Join Date: Jun 2009
1500 and still full
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation 2000: 8/15/09 - Accepted by GM. 2500: 8/18/09 - Preferenced. 3000: 8/18/09 - Accepted by Production Control. 3100: 9/9/09 - Available to Sequence. 3300: 9/9/09 - Scheduled for Production. 3400: 9/19/09 - Broadcast. 3800: 9/29/09 - Produced. ![]() 4000: 9/29/09 - Available to Ship. 4150: 9/29/09 - Original Invoice. 4200: 10/6/09 - Shipped. 5000: 10/13/09 - Delivered to Dealer. 6000: 10/13/09 - Delivered to Customer. |
#16 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
#17 | |
To All Veterans
thats what...7-15% of the cars oil capacity?? Come-on scrming, I would think surely you would have to raise an eyebrow on that much loss. If I loose 7-15% of my oil in 6k you can bet your last dollar I'm looking for a reason as to why.... not marking it off as simply normal operating parameters
#18 | |
Your post said that there was only two ways to loose oil: 1) faulty gasket 2) blow from the piston rings I simply pointed out another place you can loose oil... and while it may not be a lot, it is certainly some... I mean I had a fair amount in the tube... how much actually made it through the tube into the motor that I don' know about? What's interesting is on some of my hard launch videos you can actually seek the exhaust smoking a bit when the car really winds out... assuming this is some of the oil from the PCV... I have two LLT motors in my drive way... neither burn oil... |
#19 |
To All Veterans
#20 |
Is anyone else seeing this in their V6? I have about 8k miles on my car. I use Mobil 1 and I have to add about a 1/2 quart every 3 to 4k. My dealer said it is normal.
(I am heading out to add another 1/2 quart).
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp |
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '12 SS/RS LS3 IBM Join Date: Dec 2009
1/2 qt in 3 - 4,000 miles is next to nothing, I wouldn't give it a second thought. 1 qt in 1 to 2,000, I'd start to wonder why.
An engine has to use some oil. Anyone that doesn't agree with that can explain to me how they would expect an engine to last if it had rings that scraped cylinders completely dry on every stroke. Or valve seals that kept valve stems completely sealed from any oil. Or pcv systems that didn't recirc some oil vapors up into the intake... Cylinders are honed in a cross hatch pattern for a reason, to leave a very thin film of oil for the rings and pistons to slide on. That minor amount burns off in every power stroke. At the same time an engine is using a very small amount of oil, it is adding other things such as condensation and combustion by-products. Which makes some people think that after 3 - 5,000 miles and they check the dipstick to find it perfectly full, that motor didn't burn a drop of oil. Sure it did, a very small amount, and it also added a very small amount of other stuff = still looks full. Take a brand new car and never check the oil until 10,000 miles? I'd be very surprised if anything showed on the dipstick. New cars use a little more oil as they are breaking in. Don't replace that oil and now the lower volume will burn off even faster. The condensates and byproducts become a higher percent compared to what oil is left, take a long highway trip and it burns off like crazy. Just my opinion but if folks opened their hoods more often and kept it topped off, wouldn't be an issue to be concerned with. 1/2 qt or so between 3 - 5,000 mile oil changes is nothing. Being really low after 10K of not checking it, I wouldn't be surprised by that either. When I was a tech many years ago, saw it all the time. Especially when leasing became popular, people forgot how to open their hoods. Saw tons of leased cars pull in at around 15,000 miles with the low oil light on and a cheesed off customer that his car is "burning oil". Let me show you where the hood latch is, and here's the dipstick, and here is where you add oil.... oh no, this is a leased car, I just put gas in it. |
#22 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
Most dealers will tell you that burning a quart of oil in 1 - 2,000 miles falls within specs and is not considered excessive. I don't agree, but that is what they will tell you. That's why you are supposed to check the oil at every other gas fill-up or sooner.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#23 | |
![]() Drives: Bird Join Date: Nov 2008
As for the OP's post, I could see if you've ran it pretty hard (high rpm's burn oil on any engine) maybe it being that low on oil, but I would take it to the dealer and have them check it out to be sure. You said it wasn't showing on the dipstick, were you getting a warning message for oil level? How long after you turned your car off did you wait to check the oil? Did you fill it up and how much did it take? |
#24 | |
Drives: 2010 F150 Lariat, Candy Red Join Date: Aug 2009
#25 |
Thread Killer
Oil can be very tricky on why it’s gone sometimes.
But being diligent on checking it, if you have a problem or not is smart insurance. As it may be full one day, and a quart low the next. Ya don't wanna be racing Vetts on the low days
| Thread Tools | |
| How about a barrel of oil for around $16? | Blownhotrodder | General Automotive + Other Cars Discussion | 19 | 03-06-2009 07:25 PM |
| Synthetic? | shroomjohn | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 40 | 09-18-2008 01:31 PM |
| The 3,000 Mile Oil Change Myth | KILLER74Z28 | General Automotive + Other Cars Discussion | 35 | 07-20-2008 09:02 PM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
