Caryle Racing
Old 04-19-2013, 10:03 PM   #1
MPHS_AGM
MPHS_AGM's Avatar
Drives: 2013 Camaro 2SS/RS/1LE AGM
Reading material
Fun reading material for this weekend!
Current:
2013 AGM 2SS/RS/1LE-NPP
Past:
2002 Z28 Navy Blue A4 [traded]
1996 Camaro V6 Black [traded]
MPHS_AGM is offline   Reply With Quote
Old 04-19-2013, 11:05 PM   #2
SSRS1LE
Nice! Do you think you can find out where the pitch-sensor for the Hill Assist is located?
____________________________________
Modifications: HSA Elimination - Cold Air Inductions Intake
Solo Performance Mach Cat Back - Skip-Shift Eliminator
SSRS1LE is offline   Reply With Quote
Old 04-20-2013, 04:05 AM   #3
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
im guessing your not a fan?
coreyaustin17 is offline   Reply With Quote
Old 04-20-2013, 08:15 AM   #4
SSRS1LE
I'm not one of the 18 fans, no.
http://www.camaro5.com/forums/showth...ht=Hill+assist
I'm sure plenty of folks would appreciate a way to disable it if the answer could be found in those books somewhere. Pitch-sensor seems to be the strongest lead at the moment.
Old 04-20-2013, 12:56 PM   #5
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Subscribed
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 04-20-2013, 05:50 PM   #6
fgg60
Sweet Annie!! BRM
fgg60's Avatar
Drives: '13 2SS/RS 1LE BRM NPP CF5
me too!! HSA = suck!
FGG60 - (BRM 2SS 1LE) 1 of 70!!
fgg60 is offline   Reply With Quote
Old 04-20-2013, 07:13 PM   #7
MPHS_AGM
MPHS_AGM's Avatar
I figured that would come up. I will start looking into the manuals and see what I can find. I was also thinking if the angle tolerance could be set in the brake controller or ECM.
Current:
Past:
Old 04-26-2013, 10:07 AM   #8
MPHS_AGM
MPHS_AGM's Avatar
In my spare time (not much these days!) I have been reviewing the service manual index looking for information on the HSA. I have been through it twice and there is no direct mention of the HSA. The only lead that I have is the yaw sensor that is part of the TCS. It is mounted under the hood high on the passenger side. I am not sure if this sensor handles more than yaw (fishtailing) but the calibration steps want the vehicle on a level surface which may indicate it handles pitch output too. Might be a place to start looking.
I will start looking at the brake and TCS sections in more detail to see if the HSA shows up.
Current:
Past:
Old 04-26-2013, 06:21 PM   #9
MPHS_AGM
MPHS_AGM's Avatar
I found the HSA in the manual. It was listed in the ABS section for cars with F55 (ZL1 shocks option code). My post about the yaw sensor was correct. It is described as a multi-axis acceleration sensor which interfaces with the EBCM.
One thing that I did find is a note under the hill start assist section: "Note: The Hill start assist feature will not operate if the stability control is disabled." We should try to turn off the traction control/stabilitrak systems and see if the HSA is defeated.
Current:
Past:
Old 04-26-2013, 07:21 PM   #10
MPHS_AGM
MPHS_AGM's Avatar
By the way, I was wrong about the yaw sensor location. It can be found under the center console, not under the hood.
Current:
Past:
Old 04-26-2013, 07:52 PM   #11
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Thanks for that info. I wonder if anybody has tried it?
Old 04-26-2013, 08:06 PM   #12
MPHS_AGM
MPHS_AGM's Avatar
I created a new thread with a better title and a ZL1 tried it and it didn't work, but that is the only post so far! Here is the link
http://www.camaro5.com/forums/showthread.php?t=291779
Current:
Past:
