Cold Air Inductions
Old 04-20-2013, 07:47 AM   #1
IIxD3VOxII
IIxD3VOxII's Avatar
Drives: 2010 2SS/RS
Cleaning Your Engine
I searched the forums and had no luck but what is your process for cleaning your engine compartment and engine?
Back in the day, I used some Simple Green, let it soak a few minutes and gently rinse off. Would you recommend this or not? What do you suggest?
IIxD3VOxII is offline   Reply With Quote
Old 04-20-2013, 07:48 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
This is what I do and looks great everytime....simple green works too!
http://www.adamspolishes.com/t-Detai...ngine_Bay.aspx
Lil' Nasty is offline   Reply With Quote
Old 04-20-2013, 07:49 AM   #3
nsane
nsane's Avatar
Drives: 2013 Camaro zl1
there is a great video on here that gives you step-by-step. i will try to find it and repost.
Iowa Nice
nsane is offline   Reply With Quote
Old 04-20-2013, 07:54 AM   #4
nsane
nsane's Avatar
http://www.camaro5.com/forums/showthread.php?t=109089
and check this out - a huge DIY guide: http://www.camaro5.com/forums/showth...ht=engine+wash
Iowa Nice
Old 04-20-2013, 08:35 AM   #5
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: 2011 2SS L99 SGM 2013 2SSRS LS3 BRM
Only drive on nice days - no dirt!!
cadyshac is offline   Reply With Quote
Old 04-20-2013, 08:45 AM   #6
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
Simple green on all my engines. Run it for awhile to heat up the grease, turn it off spray simple green all over and rinse off. Try not to spray to green or the water when rinsing on the paint. It won't harm it but it will remove your wax too.
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 04-20-2013, 08:46 AM   #7
Macfolk
J.T.
Macfolk's Avatar
Drives: Camaro 2SS w/RS package, Imp. Blue
What about for those of us who leave the engine cover off? Same procedure?
Thanks,
Jason
2011 Camaro 2SS/RS L99
Mods done: 1LE replica wheels, black tail light bezels, LED driving lights (spliced to running lights), VMax CNC ported TB, No tune Vararam, and Rx catch can
Mods planned: heritage grille, 1LE splitter, led signals, tune, and possibly LT Headers
Love this car!
Macfolk is offline   Reply With Quote
Old 04-20-2013, 08:57 AM   #8
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
I've always used a brand of hand cleaner called 'Goop' for that, even when I was putting my classic car in shows. It wouldn't take the printing off my reproduction labels and stickers under the hood- but that doesn't mean you can slather it on and not remove the entire label, lol
It takes a couple hours but it came out looking like I'd just painted the engine and bucket again
ChrisBlair is offline   Reply With Quote
Old 04-20-2013, 09:12 AM   #9
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
Depending on what you have done under the hood, you may not be able to use certain cleaning products. I have coated LTs and the coating vendor said not to use any citrus based products, Simple Green, Purple Power, etc. Just something to consider.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 04-20-2013, 09:22 AM   #10
yellowrs
Drives: 2010 SS 426 V8 M/T
I use a damp rag occasionally.
Otherwise I just wipe it with my micro fiber towel.
3 years later and 15k miles my engine department still looks like brand new.
yellowrs is offline   Reply With Quote
Old 04-20-2013, 09:34 AM   #11
ChrisBlair
Buick 455 Fan
Some of us have, err, more detailed challenges re: clean engines
Old 04-20-2013, 03:46 PM   #12
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I rinse my engine compartment regularly with simple low pressure water. It keeps the dust at a minimum and prevents any build up of grease/oil. I keep the engine cover off too. Just try not to use direct water for a long time on the ignition coils, fuse box, etc.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 04-20-2013, 04:38 PM   #13
yellowrs
You would be surprised how nasty our rains and sand storms are.
The dust is a RPITB.
Putting water in your engine bay is just wild.
I wipe down my engine everyday.
Trying to make place at the next car show
Old 04-20-2013, 04:40 PM   #14
Denis
Denis's Avatar
Drives: 2010 SS
What's about with no engine cover? Coil pack and everything are exposed. Any issues as long as its not direct pressure?
