Frankenstein Engine Dynamics
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-20-2013, 09:51 AM   #1
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Help with a 850 holley carb
Just installed a wide band on the 68 at idie running 13.9 and cruse 12.5 but WOT 15.2 its, a 850 holley vacuum secondary. Fuel level is correct. Running 78 & 82 jets with rear extension. Light spring in secondary is all in at WOT.
Just thinking of going up one jet size and playing with the idle mixing screw on main would that help? Are is that to easy??
A little info on set up its a zz502. I am at 18 D base on timing all in at 3600rpm with #4 plugs AC DELCO.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 04-20-2013, 11:47 AM   #2
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
hi sir pm me any questions you have as im only too willing to help
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power HP Tuners Ngauge Diablosport SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC
dynosteve is offline   Reply With Quote
Old 04-20-2013, 11:51 AM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Your gonna want to be up around 96-98 on your jets. Thats your issue. Is the power valve blocked on that carb? What is your vacuum at idle?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 04-20-2013, 12:39 PM   #4
SC2150
Also, idle air mixture is just that, idle only. From there the air bleeds for the main circuits come into play.
Old 04-20-2013, 12:40 PM   #5
Mr. Nasty
Mr. Nasty's Avatar
Thanks I will when I check on other the thing on the curb
Old 04-20-2013, 01:11 PM   #6
Mr. Nasty
Mr. Nasty's Avatar
Will check vacuum tomorrow. That a big jump on jets but will go up on them and check power valve. Trying to get a starting point on tune.
Old 04-20-2013, 01:25 PM   #7
Mr. Nasty
Mr. Nasty's Avatar
Yeah my idle is good. Maybe the air bleeds has some thing in it are just needs to be resized ?
Old 04-21-2013, 10:11 AM   #8
willhe64
willhe64's Avatar
We use welding tip cleaners to check or hone the air bleeds out a bit.
