BORLA
Old 04-21-2013, 08:25 PM   #1
johnnyp122
Drives: Camaro v6 lfx
Trifecta tune help
Ok so I recently installed custom tune from trifecta for my car and everything flashed perfect with no problems. The car drives great and pulls harder then ever. But when I went to check out the ghost cam feature and flipped the cruise switch nothing changed. I then reflashed to stock with no ghost cam and then flashed back to custom tune with aggressive cam. And still nothing. Does it only work for the llt?
johnnyp122 is offline   Reply With Quote
Old 04-21-2013, 08:38 PM   #2
KSX
KSX's Avatar
Drives: 2010 Camaro 2SS/RS
It works for the LFX also, might just not be enabled on your tune.. Send them a message. My roommate has his enabled on his LFX sounds great.
2010 Camaro 2SS/RS IOM 6 SPD LS3
KSX is offline   Reply With Quote
Old 04-21-2013, 10:38 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Anyone gor any vids with this ghost cam on a LFX?
Mods:
Old 04-23-2013, 08:03 AM   #4
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Make sure the engine is up to temp before expecting it to work. My understanding is that coolant must be over 170F before the ghost cam activates. If you flashed, then did a cold start, it may take a bit before it comes on.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 05-04-2013, 02:09 AM   #5
johnnyp122
I recieved a email with tune update stating that the ghost cam is still in the works for the lfx. Not to worried about it tho. Just was curious to see what it sounded like in person.
