Cold Air Inductions
Old 06-24-2009, 07:56 AM   #1
copterdoc
copterdoc's Avatar
Drives: 2010 rally yellow 2LT
Temp?
Does anyone have a 180 degree thermostat? How will it affect the engine if I go to it? I am a little old school about engine temp, I know that the reason most modern engines run a 205 or so temp is for lowering emissions. I can't help but feel like running at 180 will help with engine life and performance. Anyone have any thoughts on the matter?
copterdoc is offline   Reply With Quote
Old 06-24-2009, 09:18 AM   #2
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
You`re right about emission, but it`s also allows for a more complete and cleaner combustion burn. I would leave it as is. You may be risking carbon build-up on the valves after a long period of time, carbon retains heat causing burnt valves.
mickss is offline   Reply With Quote
Old 06-24-2009, 09:24 AM   #3
montej23
montej23's Avatar
Drives: 2011 VR Camaro
interesting i didnt know that mickss, so it would be better for the engine to run hotter? Doesnt make really any sense can you explain a little more please
montej23 is offline   Reply With Quote
Old 06-24-2009, 09:53 AM   #4
mickss
mickss's Avatar
A friend of mine who is an product engineer at the GM Tonawanda Engine Plant was the person who explained to me why the newer engines run hotter than older designed engines that ran cooler. In his words, it was the Goldie Locks Therory(sp), too hot, too cold, just right when trying to obtain the most efficient(MPG`s), power and less emissions burn. Sorry bud, that`s the best I can do for an explanation.
Old 06-24-2009, 10:26 AM   #5
Vash
Drives: 00 Blazer
Yea don't change it. If you overheat something else is wrong.
Old 06-24-2009, 01:58 PM   #6
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
Well, i'd say 'run hotter than old engines'. You can really design an engine to run well at whatever temperature you want it to, and so long as it runs within that temp it will be great. But too hot or too cold and it will start having problems, as those weren't the temps it was designed for.
Brokinarrow is offline   Reply With Quote
Old 06-24-2009, 01:58 PM   #7
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Thought I would add. If you change the thermostat temp you will also have to have the computer reprogramed in order for it to go into closed loop operation.
Robert91RS is offline   Reply With Quote
Old 06-24-2009, 05:18 PM   #8
Fire
Drives: 1999 Firebird Formula
What's stock?
Fire is offline   Reply With Quote
Old 06-24-2009, 05:35 PM   #9
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
engine life would DECREASE. Oil temps would stay too low for too long except on longer trips, engine would run cold for a longer period which would promote more wear and blow-by, contaminating the oil quicker. Also, it wouldn't do any good really unless you also program the fans to come on earlier (except on the freeway). Could also lead to shorter fan and alternator life.
THE EVIL TW1N is offline   Reply With Quote
Auto Meter trans temp guage 96CAMaro 4th Generation Camaros 7 08-20-2011 04:51 PM
Engine Temp trudawg660 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 2 06-17-2009 09:59 AM
SECOND GEN WATER TEMP GAUGE INACCURATE 79ZRAG 1st & 2nd Generation Camaros 9 05-30-2009 06:13 PM
What temp does your car run/idle at? 9c1ny 5th Gen Camaro SS LS LT General Discussions 9 05-28-2009 07:42 PM
Transmission Fluid Temp Gauge l008com Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 03-08-2009 01:52 AM
