Jason 98 TA
Old 04-22-2013, 02:41 PM   #1
iceman5730
Iceman
iceman5730's Avatar
Drives: 2011 Camaro 2LT SC/RS CGM
Supercharger Oil Change
Question I am changing the oil in the IPF Blower and can not seem to get then full 4 oz back in Left the drain open for 10 mins to ensure all the old oil had drained. Was only able to put about 3 oz back in. I had drained out about 2 oz Need help was wrong
iceman5730 is offline   Reply With Quote
Old 04-22-2013, 03:18 PM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Did you remove the fill plug and dipstick while you were draining it?
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 04-22-2013, 03:26 PM   #3
sycraft
COTW 5/06/2013
sycraft's Avatar
Once the drain is open, you can blow lightly through the fill location and all the oil wiill come out, then add the 4oz bottle and you are good to go.
Old 04-22-2013, 04:09 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Do not let your wife see you perform this part of the procedure.
She's already jealous enuff of the car!
Old 04-22-2013, 04:43 PM   #5
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Unless hot, I never get the full oil change out of any of the V3 blowers, doesn't matter what kit. If its hot, most of it should come out. You have a dipstick on that lower allen plug, make sure that the oil is in the hashmarks. If you overfill it by accident all you'll see if a bit come out of the vent plug on your next drive, and you can wipe that off real quick.
Matt @ FSP is offline   Reply With Quote
Old 04-22-2013, 04:46 PM   #6
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
KalCorp is offline   Reply With Quote
Old 04-22-2013, 06:51 PM   #7
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I had about 3oz drain out. I then took a plastic straw and fit it into the dip stick fitting. I blew into the straw and about another 1/2oz came out. E-mailed Vortec and they basicly said as long as you are getting at least the 3oz out and re-filling to the proper level, that is good.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 04-22-2013, 08:52 PM   #8
iceman5730
Iceman
iceman5730's Avatar
John B.
Yes I had removed both
Old 04-22-2013, 08:55 PM   #9
iceman5730
Iceman
iceman5730's Avatar
All Good advice Thanks greatly
Old 04-22-2013, 10:10 PM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
LOL
Mods:
Old 04-22-2013, 10:48 PM   #11
Ventmaster
Ventmaster's Avatar
One bit more- as Matt@FSP mentioned, the plug that sits higher is a vent and has a brass seat.
Don't overtighten that plug when you replace it as it may close the vent and prevent it from performing its job.
Old 04-24-2013, 09:43 PM   #12
iceman5730
Iceman
iceman5730's Avatar
Done. Thanks again for your help
Old 04-15-2016, 05:24 PM   #13
omarazat
Drives: 2015 Camaro ZL1
I need little help how can I check my supercharger oil? And where all those things located at, can anybody take pictures and post it thanks in advance
omarazat is offline   Reply With Quote
Old 04-17-2016, 10:00 AM   #14
Ventmaster
Ventmaster's Avatar
Sorry, we're referring to a V-3 Vortech centrifugal supercharger. You've got something altogether different and need to check the ZL1 sites.
Good luck.
Check here- http://www.camaro5.com/forums/showth...ght=oil+change
