autoguy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions
Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions Performance driving discussions
Old 06-24-2009, 08:18 AM   #1
larietrope
Drives: 1969 Chevelle SS
once more please M mode on L99
This is not about going down the drag strip but for best acceleration/response around town.
If I drive around town in M mode (only) will the car start in first gear and shift itself automatically ? Is this the best for max acceleration ?
I read in the handbook if you do go into M mode and come to a stop, the transmission will revert back to second gear starts unless you go out and back into M each time.
Any thoughts ?
larietrope is offline   Reply With Quote
Old 06-24-2009, 08:52 AM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
shifter im M and S displayed on your dic will start in 1st gear at every complete stop
Old 06-24-2009, 09:31 AM   #3
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
something am trying to figure out. what made people think it starts in second gear if its in sport mode
trudawg660 is offline   Reply With Quote
Old 06-24-2009, 10:49 AM   #4
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Well I had to edit my previous post.
I took my car out for a test this afternoon and it sure seems as if 1st gear is used when the shifter is in M mode (when not using the paddle shifters).
The reason I say this is because when I start out from a dead stop, I get a little bit of wheel spin off the line and then it shifts at 6000-6100 rpms (around 35-37mph) into second gear.
If it was starting out in 2nd gear it wouldn't hit redline at 37mph and shift. So it must be in 1st gear?
SGOS252382 is online now   Reply With Quote
Old 06-24-2009, 11:33 AM   #5
trudawg660
have you thought about this. when you shift into M mode. and you push the left shifter "M1" comes up because that’s as low as it can do not because it was in M2. and when you click the right paddle M2 comes up because you just shifted out of 1st into second.
if it’s already in 2nd gear when you shift to "M" why won’t it shift to 3rd when you click the right shifter
Old 06-24-2009, 03:45 PM   #6
SGOS252382
SGOS252382's Avatar
I had to edit my previous post. I'm pretty sure it starts out in 1st gear from a dead stop in M mode and D (regular Drive).
Go out and mash the gas from a dead stop using M mode. Your car will hit redline and shifts around 35-37mph. So it has to be in 1st gear.
L99 (best mode for racing?) SGOS252382 Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions 20 03-17-2013 08:49 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
L99 how best to use M mode ? larietrope Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions 3 06-23-2009 07:39 AM
Any exhaust sound clips of L99 in 4 cylinder mode? SubSolar Camaro Photos | Spyshots | Video | Media Gallery 10 06-07-2009 01:30 PM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
