SDTW Custom Wheels & Tires
Old 04-22-2013, 10:18 PM   #1
asprex
Drives: 2012 2ss
Dual mode exhaust
Could someone with a dual mode exhaust post pictures of the vacuum valve and vacuum source for the muffler valves. I'm installing the NPP exhaust on my 2012 ss and have not seen a factory install. Thanks.
asprex is offline   Reply With Quote
Old 05-07-2013, 04:59 AM   #2
ahesq
Drives: 2014 C7, 3LT, manual
I added NPP Dual mode exhaust to my new 2013 as well. Adding the new pipes was the easy part.
However, to control the flaps, the dealer was forced to use an aftermarket "NPP in a Box" vacuum actuator (sells for about $170.00) since it could not replicate the factory option. It is a simply on/off set up you control by key fob, or you can also program the switch to your homelink garage door opener buttons.
Apparently, while NPP is an easily installed $895.00 option at the GM assembly line, adding it after production would require not only VERY expensive GM vacuum parts and electrical relays, but also computer software flash modifications to both the engine control and fuel management systems - which they could not do, even as a GM dealer.
Let me know if you find out differently, as they spent nearly a week researching this for me before going with "NPP in a Box". I would have loved to install the GM factory "automatic" function, but NPP was the 1 option my car did not have.
The one draw back to the NPP in a Box is that closed flaps is too mild, and open flaps in normal driving is just too loud, with huge low end "drone" at highway speeds. They sell aftermarket flap "adjusters" for $25.00 so you can close only 90% flaps, for example. They are simple clamps you attach to the actuator rods to stop them from closing all the way when vacuum is applied. You can adjust the amount of flap closing by the chosen placement of the clamps on the rods.
ahesq is offline   Reply With Quote
Old 05-07-2013, 02:05 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
The back of the LS3 intake manifold has a vacuum port
Old 05-14-2013, 10:06 PM   #4
Nick821
Nick821's Avatar
Drives: 2013 BRM SS/RS Convert
Does anyone know where the L99 vacuum port is if any?
Nick821 is offline   Reply With Quote
Old 05-14-2013, 10:20 PM   #5
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I didn't think the auto came with dual mode?
Old 05-14-2013, 10:38 PM   #6
Nick821
Nick821's Avatar
Auto didn't, however I have the opportunity to buy a complete NPP catback and want retro fit it to my 2013 L99
Old 05-15-2013, 07:38 AM   #7
Zorns
Zorns's Avatar
Drives: ?
I was under the impression there was more to the hook-up than vacuum lines. Thought I read somewhere in another thread about electronic module and error readings.
Zorns is offline   Reply With Quote
Old 05-15-2013, 09:43 AM   #8
Nick821
Nick821's Avatar
Zorn: Yes, I was looking to use the after-market "NPP in a Box" setup but not sure if the L99 intake manifold has the same vacuum port on the back like the LS3 one.
Old 03-18-2015, 01:49 AM   #9
hexxJessCamaroSS
2016 Camaro 2SS
Drives: 2016 Camaro 2SS
I just purchased a NPP compete exhaust system. I have a 2012 SS automatic though. Anything I need to know before installing this system?
hexxJessCamaroSS is offline   Reply With Quote
Old 03-18-2015, 04:37 AM   #10
z3R0fo01
z3R0fo01's Avatar
Drives: 2014 1SS RS 1LE tvs2300
I capped my vacuum line after sc install and it sounds great. No need for dual mode lol
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned
z3R0fo01 is offline   Reply With Quote
Old 03-20-2015, 09:11 PM   #11
PwrCrusr
PwrCrusr's Avatar
Drives: 2014 1LE
Any full time vacuum source should work so long as you aren't upstream of any sensors. I'd hook the exhaust up and just leave it open all the time - hook the vacuum line up if you go in for an inspection and have noise requirements or get one of the aftermarket switched controllers. The flaps will always be open on startup until the engine builds vacuum though.
2014 1SS 1LE SIM RS NPP
PwrCrusr is offline   Reply With Quote
Old 03-21-2015, 07:19 PM   #12
Wollmank
Drives: 2014 Camaro 2SS/RS 1LE AGM
I have the NPP but I pulled my fuse so it don't work. Sounds better without the dual mode. No sense in getting NPP I wouldn't think unless you like the look.
Wollmank is offline   Reply With Quote
Old 03-23-2015, 01:20 AM   #13
Camaro Dude
and Sledge
Camaro Dude's Avatar
Drives: '13 1LE, 2SS, NPP
The NPP literally wakes up, in significant increments might I add, with every single bolt on mod that you throw at it, lol.
That fuse will be going back in short order after one installs LT and off-road pipes.
Not yet some might say? Well then add a cam for good measure, and particularly in cold weather when the air is nice and dense, you will be the first in line to buy a NPP controller switch for permanent shutting off of the flaps when driving around conservative areas.
Camaro Dude is offline   Reply With Quote
Old 03-23-2015, 07:58 AM   #14
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
You are not kidding sir!!!
After the header install I set mine up to be able to keep them closed, just as a courtesy for my neighbors.
After the cam install , it was a requirement to be able to tame the beast. You would swear they are not the same exhaust at this point, there is no longer a resemblance to the much more tame factory sound.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
