BeckyD@RodgersChevrolet
Old 04-22-2013, 11:21 PM   #1
vandervortadam
Drives: 2010 Camaro 2ss black 21's
Wideband O2
Just wondering where to put them and can i put them in myself. Do they replace my ones in the car now?
Posted from Camaro5.com App for Android
vandervortadam is offline   Reply With Quote
Old 04-23-2013, 12:15 AM   #2
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Due to not having cats and having my rear o2's tuned out, I just out it in place where the rear o2 would be on the passenger side.
sent from my galaxy s3. that would explain the errors.
xjer22x is offline   Reply With Quote
Old 04-23-2013, 04:52 AM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
No, they will not replace the ones you have now. You need to have another bung welded in pre-cat. Driver's side is preferred by most as it runs a bit leaner.
Iam Broke is offline   Reply With Quote
Old 04-25-2013, 01:00 PM   #4
vandervortadam
So if i go catless which i plan on doing i can use the rear hole. Is that in the stock pipe then?
Old 04-25-2013, 01:54 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Yes, if catless and you disable the rear 02's in the tune you can use one of those bungs.
Old 04-25-2013, 06:29 PM   #6
vandervortadam
Sweet easy solution.
