Old 04-23-2013, 01:35 PM   #1
TedW
TedW's Avatar
Drives: 2012 Camaro SS
Drivetrain Info
1LE Transmisison ...
RPO MG9
Trans Name Tremec 85mm
First 2.66
Second 1.78
Third 1.30
Fourth 1.00
Fifth 0.79
Sixth 0.63
http://www.vibratesoftware.com/html_...nsmissions.htm
Also for drivetrain check ...
http://www.gmpowertrain.com/VehicleE...nProducts.aspx
TedW is offline   Reply With Quote
Old 04-23-2013, 01:38 PM   #2
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Why do I remember different ratios published for 1LE? Like .5 for 6th
If you are referring to MY 13 then look for code MM6
Southern Comfort is offline   Reply With Quote
Old 04-23-2013, 01:56 PM   #3
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
RPO MG9
First 2.66
Second 1.78
Third 1.30
Fourth 1.00
Fifth 0.79
Sixth 0.63
If you check the application page listing for the MG9 is says it's for the ZL1 and the CTS-V.
For the 1LE you need to look for MM6. that application list is Camaro and Corvette.
Nick S is offline   Reply With Quote
Old 04-23-2013, 02:34 PM   #4
MarkSS
MarkSS's Avatar
Drives: 2014 Z/28
The transmission listed is not the 1LE transmission. 1LEs use the MM6 version of the Tremec 6060. 1LE ratios are as follows:
First 2.66
Second: 1.78
Third: 1.30
Fourth: 1.00
Fifth: 0.74
Sixth: 0.50
Reverse: 2.90
MarkSS is offline   Reply With Quote
