Old 04-23-2013, 11:58 PM   #1
kansjfr
Drives: 2013 2SS 1LE
Tire rotation
Are the front and rear wheels the same on the 1LE; that is, can they be rotated front to back? I think the tires are directional, so they can't be rotated side to side. I thought I saw something on here indicating that the offset on the wheels is different front to back, so they can't be rotated front to back. Inquiring minds want to know.
kansjfr is offline   Reply With Quote
Old 04-24-2013, 12:09 AM   #2
JJKJ
JJKJ's Avatar
Drives: 2013 2SS/RS 1LE
Wheels are different front and back so if you want to rotate, you'll have to a dismount/remount.
John
13 VR 2SS/RS 1LE (sold)
01 Z28 M6 HT
JJKJ is offline   Reply With Quote
Old 04-24-2013, 12:27 AM   #3
kansjfr
OUCH! Thanks for the reply.
Old 04-24-2013, 07:55 AM   #4
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Has anybody bought 2 more front wheels for the rear? Will the 20x10s work in the rear? Are they the correct backspacing, etc? A true square setup would be rockin!
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 04-24-2013, 03:54 PM   #5
RXV_POOR
Drives: Looking to buy
Question
has anyone considered or tried putting two 11" wide rears on the front?
RXV_POOR is offline   Reply With Quote
Old 04-24-2013, 04:03 PM   #6
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Someone did (by accident - wheels were marked wrong) and they hit. 11" wheels will not fit on the front. Has anyone thought about rotating tires on the rims (front tire to back rim - back tire to front rim), or is the risk of rim damage to great?
gajagfan is offline   Reply With Quote
Old 04-24-2013, 05:38 PM   #7
davidcroft
davidcroft's Avatar
everytime you dismount/remount you risk damging the rim and tire....I've seen it firsthand on a ZR1. The tech was NOT excited!
Old 04-24-2013, 06:03 PM   #8
gajagfan
gajagfan's Avatar
Thought it might be a bad idea. Thanks!
Old 04-24-2013, 06:28 PM   #9
cornerspeed92
cornerspeed92's Avatar
I haven't read anyone yet saying any thing,but these tires are specific to right and left side only!
cornerspeed92 is offline   Reply With Quote
Old 04-24-2013, 06:33 PM   #10
RXV_POOR
you wouldn't happen to know by how much the fronts hit would you? A good body shop could roll the fenders or add a good flair to fix the clearance issues.
Old 04-24-2013, 07:53 PM   #11
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
The rub the suspension (ie: inside of the wheel), not the fender.
If you want a bigger wheel in the front, you have to go aftermarket and get the correct back spacing.
And there is no real reason to rotate. The whole purpose of rotating (for cars with the same wheels and tire sizes front and rear) is to get even wear on the fronts and rears, and thus replace the entire set at one time. There is no problem with replacing them in pairs as they need to be replaced.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 04-24-2013, 08:27 PM   #12
RXV_POOR
Thumbs up
Thank you for the info
Old 04-24-2013, 08:45 PM   #13
gajagfan
gajagfan's Avatar
The rotation helps prolong any replacement as the centers on the back wear as the corners on the fronts wear. I guess it just can not be worried about with this car.
Old 04-25-2013, 08:33 AM   #14
Zorns
Zorns's Avatar
Drives: ?
I know the 11's won't work in the front....but can you put 10's on the rear?
Zorns is offline   Reply With Quote
