Old 04-24-2013, 08:52 AM   #1
NoleLife
NoleLife's Avatar
Drives: 2013 2SS M6
[UPDATE]: Rattling/Tapping sound coming from engine (2SS)
I posted a few days ago, with a video from under the car, of a tapping/rattling sound coming from under the car. I got back ideas of exhaust leak, bad lifter, loose metal, etc. I sent the video link to my dealer and their service tech said if it isn't louder under the hood then it may not be a lifter and could just be an exhaust leak. I'll be taking it in there in a day or 2 to have it looked at, but I decided to pop the hood and see if it was louder or not. Here is the sound:
Should I be worried?
NoleLife is offline   Reply With Quote
Old 04-24-2013, 10:00 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I honestly don't hear anything strange.
FSP tuned: 377/389
Old 04-24-2013, 10:12 AM   #3
NoleLife
NoleLife's Avatar
Drives: 2013 2SS M6
You have eased my concerns.
Old 04-24-2013, 01:04 PM   #4
jordan 572
jordan 572's Avatar
Drives: none
Video is pretty clear but still hard to hear since its still a video, sounds like normal valve train noise though if you ask me.
jordan 572 is offline   Reply With Quote
Old 04-24-2013, 01:08 PM   #5
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
these cars have a sewing machine sound to them. some ppl recommend running about 7 quarts of oil instead of 8 or 9. cause the crank mixes the oil and causes air bubbles. which is where the noise is coming from. not enuff oil being pumped to the top . thats something u will have to decide. but thats a pretty common noise i hear it tho.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 04-24-2013, 01:19 PM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
I've read this about the oil and find it somewhat true. I used 7.5 qt's last oil change and the engine is much quieter.
I've also heard that Pennzoil Platinum also helps to quiet the lifters; I will be switching to this on my next oil change.
But who uses 9, the car calls for 8qt's?
FSP tuned: 377/389
Old 04-24-2013, 01:28 PM   #7
NoleLife
NoleLife's Avatar
Drives: 2013 2SS M6
When I had it taken in for my oil change (at the dealer) about 2-3 weeks ago at 5k miles, they commented on the fact that it took 8.5 qrts. This might explain some things...
I went with Mobile 1 synthetic, but maybe I'll take it in again at 8k and tell them to oil do 7.5
Old 04-24-2013, 01:30 PM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
8.5? The manual clearly says 8qt, I can assure you this is part of your problem.
I'd highly recommend draining a bit out, more oil can be worse on an engine then less oil.
I also wound never go 8K between changes, but that's another debate.
This is from the manual:
6.2L V8 Engine 7.6 L 8.0 qt
FSP tuned: 377/389
Old 04-24-2013, 01:48 PM   #9
NoleLife
NoleLife's Avatar
Drives: 2013 2SS M6
Nooo, I'm not going 8k between changes. I did my first one at 5k. Said my next one will be @ 8k (so 3k between the first and upcoming change)
Old 04-24-2013, 01:55 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
FSP tuned: 377/389
Old 04-24-2013, 01:57 PM   #11
thepirate
thepirate's Avatar
Drives: 2013 2SS
I have no insight or help whatsoever... all i can say is good luck. It's the worst when you think something might be wrong.
thepirate is offline   Reply With Quote
Old 04-24-2013, 02:10 PM   #12
NoleLife
NoleLife's Avatar
Drives: 2013 2SS M6
Agreed. The second I heard the sound for the first time my heart sank and I just said to myself "What the s**t is that sound!?".
But I sent the video to the original dealer I bought the car from and they said it doesn't sound like a lifter and that it's *possibly* an exhaust leak. Between that, and everyone hear saying it sounds normal, I feel comfortable thinking that there is nothing major mechanically wrong with it. It's likely too much oil put in it, and in the worst case it's an exhaust leak.
I had just started toying with the idea of doing headers and a tune but this small scare has me doubting wanting to lose my warranty now though.
Old 04-24-2013, 02:19 PM   #13
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i couldnt remember off the top of my head. what it was thats why i said 8 or 9
but on a completely drained engine 8.5 to 9 is what it will hold.
Old 04-24-2013, 02:20 PM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
FSP tuned: 377/389
