Old 04-24-2013, 08:05 AM   #1
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
P1133 and P1153
I thot I fixed this problem but then it kicked out more O2 codes. What can I do to fix this?
adrwhi is offline   Reply With Quote
Old 04-24-2013, 01:28 PM   #2
catalan
Drives: -
According to my knowledge, those codes come mostly after putting on new set of headers .. Your tuner should fix and clear the code .. if it comes again, you might need to replace/modify your O2 sensors into one wire instead of using an extension to plug it all the way ..
catalan is offline   Reply With Quote
Old 04-24-2013, 01:38 PM   #3
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
Yeah my bad for lack of info. I already had a dyno tune, and yes it comes from putting on LT headers. Sigh I swear this is like my 4th time driving up to this place to get my tune right smh.
Old 04-24-2013, 02:42 PM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
You can avoid all that with JRE Custom Tuning via Email.
With over 1400 Gen5 Camaro tunes to date No one knows your Car Better.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 04-25-2013, 09:56 AM   #5
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Most of the causes for the 1133/1155 codes are the front O2 sensor and or its wiring has a malfunction.
When guys install headers, sometimes the O2 sensors get banged up while hanging, sometimes they get crossed, the O2 sensor isn’t tight enough in the bung, or the wires can melt because they are too close to the headers all of which will prevent the sensor from doing its job as a narrow band.
The PCM detected less than 55 lean to rich or rich to lean switches on the on the sensor, or more common, that the sensor signal remained fixed between 300-600 MiliVolts (mv) during a two minute test period in closed loop. Scanning the vehicle would help.
It can be turned off so it doesn’t throw a code, but calibration normally is not a factor for the front O2 sensors to throw the code.
Your front O2 sensors are in place to retrieve an air sample pre cats. Your rear O2 sensors are in place to take an air sample after the cats to determine how effective your Cats are working.
Phil
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 04-25-2013, 01:57 PM   #6
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
Yeah I don't have any cats so I probably just get it turned off. Will this do any harm to my vehicle?
Old 04-25-2013, 02:00 PM   #7
kcox2010
synergy2011
kcox2010's Avatar
Drives: 2011 synergy green 1ss/rs
Send a message via AIM to kcox2010
I trying to fix my brother car with the p1133 comes on once a year
2011 synergy green ss/rs,rally stripes, cai with air ram scoop, hawks brake pads, solo mach x exhaust with jpipes, slp gill inserts,stainless power headers high flow cats, zl1 grille, vmax tb, chrome wheels, powder coated calipers, stainless brake lines, elite catch can,dyno jet 471/425tq,oracle black ghosted side marker, mailslot graphic, rpi design interior trim pieces, front and rear footwell lighting,afterburn sequential tailights, custom lighting engine bay, custom comp cam new era performance
kcox2010 is offline   Reply With Quote
Old 04-25-2013, 03:24 PM   #8
Tampa Tuning
having cats or not doesnt play a factor with those codes. It simply checking to make sure the sensor is working.
You do want your front 02s working properly
Old 05-01-2013, 10:24 AM   #9
adrwhi
MonstaBGP
adrwhi's Avatar
Drives: Shadow
I sent you my back up file, not sure if you got it. Let me know if you didn't
