Old 04-24-2013, 03:38 PM   #1
jfcamaro
jfcamaro's Avatar
Drives: 2012 V6 Black on Black Camaro
2012 v6 oil issue
I have a 2012 v6 and it has 32,000 miles on it and it started using oil oil like crazy then started ticking! I brought it to the dealer and they said they think its the timing chain loose. It would only do it under a load! They told me that Gm said I had to drive it a 1000 miles to do a fluid check. I was not happy that Gm would make me drive it 1000 miles with it sounding so bad! So I did what they wanted and no they tell me indeed it is burning a lot of oil and Gm is making them go through the whole motor that I guess takes a ton of man hours to do! The service women said the tec wasnt real happy to have to spend so much time and I have to say that didn't make me feel all warm and fuzzy!! So here I sit and wait to see what happens next! Driving a Rental that I get according to them only five days?? Anyone else having this issue!! I love my ride and this just sucks!
jfcamaro is offline   Reply With Quote
Old 04-24-2013, 03:40 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
This is a pretty common issue with these cars, do a seach and you'll find others.
FSP tuned: 377/389
Old 04-24-2013, 03:45 PM   #3
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
The tech wasn't real happy to have to spend too much time on it? Well too bad. He's getting paid for the work. Boy some dealerships suck! Hopefully it won't take too long. I also hope the rental car is on them. Good luck!
06_warrior is offline   Reply With Quote
Old 04-24-2013, 03:46 PM   #4
kostnkost
Roof expert detail noob
kostnkost's Avatar
Drives: 2013 BRM 2LT RS
I am curious if this is happening with the 2013's? I just hit 10k on mine and have not had any issues as of yet(fingers crossed)
Anyone know if GM fixed this problem with the 13's?
kostnkost is offline   Reply With Quote
Old 04-24-2013, 03:55 PM   #5
jrisebo
jrisebo's Avatar
Drives: 2011 Camaro RS "Bumble C"
drive it a 1000 miles in first gear, then they can buy you an engine and a tranny. GM DEALER FAIL
jrisebo is offline   Reply With Quote
Old 04-24-2013, 04:20 PM   #6
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
I have 36000 miles on my V6 and it burns a little oil, I have always kept a good eye on it, in fact every time I fill up I check it, now issues yet here.
007s 'Vert is offline   Reply With Quote
Old 04-24-2013, 05:26 PM   #7
jd10013
Drives: 2012 camaro
from what I understand it was a problem on the LLT's and corrected on the LFX. so 2012 and up should be fine.
jd10013 is offline   Reply With Quote
Old 04-24-2013, 05:43 PM   #8
v6_camaro
v6_camaro's Avatar
Drives: 2013 Camaro 1LS
Report to GM that you're not happy with the dealership and go to a different one. The dealership where I bought mine did a sloppy job installing the GFX. They dinked the right front fender at the body line and didn't snap the rear bumper in place. In your case, you have an engine issue that can be more costly to repair if it's not done right. If the tech wasnt' happy doing the work, there's a good likelihood that the job wasn't done right.
v6_camaro is offline   Reply With Quote
Old 04-24-2013, 06:04 PM   #9
Scooter11
Scooter11's Avatar
Drives: 2013 SW 2LS
I have a 13 and I'm hearing a fairly noticeable tick. I have only 2100 miles... it could be normal though
Scooter11 is offline   Reply With Quote
Old 04-24-2013, 08:44 PM   #10
Chevrolet Customer Svc
Drives: GM Vehicles
Hello jfcamaro,
I understand your frustrations with the wait and time away from your vehicle. I would like to monitor this situation. If possible, could you private message me your name, VIN#, current mileage and involved dealer information? I will contact your dealer to inquire about the process going forward and follow up with you.
Reggie B.
Chevrolet Customer Care
Old 04-24-2013, 10:20 PM   #11
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
That's what I thought as well, but the OP has a 2012 (LFX).
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 04-24-2013, 10:23 PM   #12
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
These motors normally have a tick to them. You can thank the DI a d VVT for that.
Proud owner of litho #179 Click Picture for Build Thread
Old 04-24-2013, 10:51 PM   #13
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Oh man that sucks,. I'd consider trying another dealer.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 04-24-2013, 11:10 PM   #14
KMPrenger
KMPrenger's Avatar
Hrrrmmm...timing chain issue is well known with the 2010s and 2011 V6s. Thought maybe it was fixed with the 2012s, but then again I thought I read from someone here that maybe the real source of the issue wasn't corrected until the 2013 model.
Hell who knows. I do know that at some point the 2011s and up got a stronger chain than the 2010s which helps. What you really have to do is keep up on frequent oil changes and check the oil level often, which is a shame but it is important to keep an eye on things with this engine.
GM is well aware of the issue, and they should cover you. I've read of many other cases of this on here where GM did the work under warranty, even on some modded V6s.
